weak start? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-01-2013, 08:47 PM Thread Starter
weak start?
i have a 04 6.0 and a few months ago i replaced the fuel pump, filters and injectors, CAC boot and just recently all ball joints, bearings, and seals(PAIN IN THE *** btw lol) but ive always noticed that my truck has a weak start i guess youd call it. My buddies 02 7.3 starts up strong he turns the key and she starts nice and strong as opposed to mine. Mine turns over strong then sounds weak. it only happens when its a cold start like after my truck has been sitting. FICM is good and i took a voltage meter out there earlier and both batteries read between 12.5-12.7 volts does that means the batteries are fine or should i crank it and measure the voltage? Its got me stumped cant drive the truck right now because shes on jackstands waiting on her 20x12s to arrive
duracrap is offline
post #2 of 8 Old 08-01-2013, 10:10 PM
Well, do your glow plugs work?
JorgeCanek is offline
post #3 of 8 Old 08-01-2013, 10:51 PM Thread Starter
according to the dash light they do...no check engine light and my PMT isn't showing any DTCs
duracrap is offline
post #4 of 8 Old 08-02-2013, 09:28 AM
You need to do a load test of the batteries to see if they can deliver enough amperage not just voltage. You can have 13v but only 1 amp availble and a starter cant even turn over.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 8 Old 08-02-2013, 10:06 AM
Quoted: 50 Post(s)
Yep, exactly right. And be sure to disconnect the cables from each battery before testing. My friends truck did this and it turns out the drivers side battery was shot. Best to replace both batteries at once, since when one gets weak the other gets overworked and fails soon thereafter.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #6 of 8 Old 08-02-2013, 11:32 AM Thread Starter
yeah that's what i was going to do. i have a feeling the batteries are whats causing this i work at o reillys so whenever my wheels get in ill test take it to work and test them. the dates on the batteries are either from 09 or 10 if i remember correctly. any recommendations on a good set of batteries? We have people that swear by the red tops but some people say theyre the worst batteries they've ever had. anyone have any personal experience?
duracrap is offline
post #7 of 8 Old 08-02-2013, 12:07 PM
Quoted: 50 Post(s)
Frankly, the motorcraft 850s are a preferred battery for these trucks, and they generally last 4 to 5 years. Optimas don't do very well for these trucks.
Icon 2.5 CDC Shocks
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #8 of 8 Old 08-02-2013, 06:02 PM
Trucker's Avatar
I just bought 2 motorcraft 850 batteries and my truck starts better than it ever has and when I bought the truck 3 years ago the dealer put napa legend 75 in it. I have only had the motorcraft for a week but I'm happy so far.
2005 F350 FX4 CCLB SRW
BPD Heavy Duty Oil Cooler With Factory Oil Filter
BPD EGR Cooler. Updated STC Fitting
Updated Turbo Oil Drain Tube
Blue Spring And 6.4 Banjo Bolts
Bypass Coolant Filter
Edge CS Monitoring System And Glow Shift FP Gauge
Shell Rottela ELC And Cetane Booster In every Tank
Trucker is offline
