2005 6.0 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-29-2013, 05:05 PM Thread Starter
Looking for some info on the gem modul and the engine control modual can't remember exact name but my Matco computer say I have and issue with both anyone know about these?
priussmoker is offline
post #2 of 6 Old 07-29-2013, 06:39 PM
Could you explain a little more?
JorgeCanek is offline
post #3 of 6 Old 07-29-2013, 06:46 PM Thread Starter
I hooked up my Matco determinator diagnostic tool due to a long crank today just replaced my hpop dummy plugs stand pipes and o-rings about three weekes ago, do after the long crank today I was worried had three fault one was crank shaft position sensor one was the gem modual and the engine communication bus I believe, I know that ford has to replace them so they can re program the truck just wondering if anyone has had a similar problem truck still runs awesome stars fine and goes good but have those two codes replaced crank shaft sensor
post #4 of 6 Old 07-29-2013, 07:21 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 53 Post(s)
Feedback Score: 7 reviews
Gem is general electric module. Controls things like radio, locks, windows.
For the Ecm code, give us a PXXXX type code.
I think that's what you are asking
2007 Ford F-250 XL 6.0L Powerstroke 4x4
God bless America, the Constitution and the Second Amendment.
Archoil gangbang - don't be the soggy biscuit
powerstrokeshellback is offline
post #5 of 6 Old 07-30-2013, 02:00 AM
mustangmike6996's Avatar
I was told that there is no GEM in the trucks after 02. I guess everything is in the relay box under the dash. This info came from Trousley Ford.
I cant remember the exact name but It sounded like an updated name for a GEM
mustangmike6996 is offline
post #6 of 6 Old 07-30-2013, 03:54 PM
x148's Avatar
So does the truck start or no after all that work you did?
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
