Over heating then eventually white smoke please help!!!!! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-27-2013, 07:19 PM Thread Starter
Send a message via Skype™ to fathead1107
I was driving my fan got louder then eventually my rig started over heating I thought it was my thermostat. I was delivering it home then white smoke started pouring out of my exsuast. There was no fluid leakage anywhere I cracked my radiator cap let off pressure and left it loose so it would not build up pressure. It drove fine after that. I made it home. I am in the army I use my truck to get to work it's essential I have it up and running ASAP please help. I need to kno what to to. I used to be a mechanic in the army I switched over to infantry. But I can work on my rig I just need a bit of help please help.
fathead1107 is offline
post #2 of 11 Old 07-28-2013, 06:44 AM Thread Starter
The next morning
Ok I checked all my fluids this morning the only thing that is wrong is my coolant so I put some water in my truck. I started it it ran it was good, so now I am on a drive. There was a bit of white smoke at first but I guess it was coolant still burning off. I drove the truck no problems so far it's regulating temp just fine. I am pretty sure it's the egr valve I want to get a delete kit for it. Do I need to but a oil cooler for it or no? I read if the egr valve gose out then I need to replace the oil cooler. But why? Please help
post #3 of 11 Old 07-28-2013, 06:51 AM
x148's Avatar
Well when I did my EGR delete I installed a new cooler, I figured while I was in there mine as well go ahead and change that too. I would keep an eye on your coolant level and watch that temp gauge carefully, you DO NOT want to overheat your truck, bad things will happen.
Also where are you stationed? And good man making the switch to 11B. I was Infantry for 4 years
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
post #4 of 11 Old 07-28-2013, 06:54 AM
Most of times, when the egr cooler is leaking, the real problem is the oil cooler, because the water section is clogged and not enough water goes to the egr, thus overheating the tiny metal walls and breaking them.
Also, if your oil cooler isnt bad you should change it... You are already taking out the whole valley section and the cooler is just about 15 bolts to get it out, and you will have a reliable truck. Hope it to you makes sense
JorgeCanek is offline
post #5 of 11 Old 07-28-2013, 08:45 AM Thread Starter
ok well you guys think its def my egr and not a head gasket. i gotta fix this asap. but i am ant fort campbell ky 101st airborne. did you do the job your self i hate having people work on my truck. i am pretty sure i am capable of doing this to my truck. how is your delete kit also i saw that someone took the egr off and just welded a plate on to it. it seemed pretty lagit but i want to ask around
post #6 of 11 Old 07-28-2013, 09:42 AM
x148's Avatar
I am a diesel mechanic so yes I did it myself, its a easy job. I ordered the sinister EGR delete kit and it came with a new oil cooler. No welding is needed, everything is bolted on. The biggest pain is the exhaust as the bolts are usually rusty and difficult to get to. Just make sure you have the new o rings and gaskets for some of the components. I was 1/25th out of Ft lewis and 2SCR out of Vilseck Germany, Baghdad & Baqubah Iraq 2007-2008. Stay safe brother.
05 F350
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-Pro Comp Trac Bars
x148 is offline
post #7 of 11 Old 07-28-2013, 10:23 AM Thread Starter
awsome i think i am going to do it on my own. i did my own exsuast on my old 7.3 and had no problem. but where did you find it in a package deal? i would love to find a egr delete kit with oil cooler and tuner and or chip. i am going to get a aer loan i am sure you know what that is money is tight right now and its no interest loan.
thx man for watchin my six
post #8 of 11 Old 07-28-2013, 10:27 AM
x148's Avatar
I hear ya, you need to find some side work. This is the kit I bought, comes with everything you need.
Basic Solution(TM) for Ford 6.0L Powerstroke With Sinister EGR Delete Kit, Oil Cooler and Intake Gaskets
05 F350
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-Pro Comp Trac Bars
x148 is offline
post #9 of 11 Old 08-01-2013, 03:36 PM Thread Starter
i am starting this project tomorrow. i bit nervious scinsister sent me instructions on how to install the delete kit but now the oil cooler do you know where i could look to find that
post #10 of 11 Old 08-01-2013, 06:56 PM
Quoted: 239 Post(s)
buy yourself a set of flex head ratcheting boxend metric wrenches. make sure they go all the way down to 8mm. it makes the job almost fun. its almost the only tools you need for this job
2005 F350 srw Crewcab lariat. 6.0 diesel
nitrogen is offline
