Turbo screaming - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-26-2013, 05:35 PM Thread Starter
still runs's Avatar
Turbo screaming
Just finished up oil cooler job and once I hit 5lbs boost or more it sounds like my turbo is screaming for help its not a whistle its a screaming sound like when you put a peice of grass between your thumbs and blow checked all the boots and clamps everything is tight and not leaking as far as I can tell but I don't know any how help would be great thanks
arp studs and all new gasgets
blue spring.... its really blue
full egr delete
Bts tranny
coolant bypass and fillters
rotella red elc
cummings 5.9l banjo bolts
4 inch turbo back
Custom tunes by spe
2.7 leveling kit
next on the list
new injector$ $$$$$
regulated fuel return
ficm & ecm to php along with my evo to be flashed
and half in my 401k lol
still have my 401k all of it
SYLSOS
still runs is offline
post #2 of 5 Old 07-27-2013, 01:11 AM
What year? I can't decide if you have a problem or if your only finally hearing the natural turbo scream of a 6.0. The 03's were really loud.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 5 Old 07-27-2013, 05:28 AM Thread Starter
still runs's Avatar
I've had this truck for 3 years its never made this sound its gotta be a leak some where now that I think about it because I'm only makeing 25lbs boost on normal i make 30+ with no problem but hey thank you for your help
full egr delete
Bts tranny
rotella red elc
4 inch turbo back
Custom tunes by spe
2.7 leveling kit
next on the list
new injector$ $$$$$
SYLSOS
post #4 of 5 Old 07-27-2013, 06:01 AM
ADMIN AND TECH
SCUFFY828's Avatar
you have a leak somewhere between the egr cooler ends or a y-pipe is cracked , seen this many times and know exactly the noise you hearing , the most common place to look is at the clamp where the rear egr port clamps to the up-pipe , the metal gasket may have fallen and gotten it to not seal up there , or even the clamp is loose
ITS STOCK
SCUFFY828 is offline
post #5 of 5 Old 07-27-2013, 06:16 AM Thread Starter
still runs's Avatar
Cool deal will have to check that all out but here's one for ya if it was exhaust thats leaking why cant I hear it sitting still and taking my rpms up or sitting there in gear brake to the floor and doing the same thing slowly take my rpms up and build boost ??? Thanks and I will check all the clamps and joints
full egr delete
Bts tranny
rotella red elc
4 inch turbo back
Custom tunes by spe
2.7 leveling kit
next on the list
new injector$ $$$$$
SYLSOS
