Dog Whistle in the Engine? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-26-2013, 05:58 AM Thread Starter
Gus_hauler's Avatar
After my head gasket replacement I am noticing a new noise. When driving down the road, at 50-55 for example, if for some reason I have to roll on the gas, or I go up a little grade, I hear a VERY, VERY high pitched whistle from the right side of the truck. It is so high pitched it sounds like it is almost out of my hearing range.
When it happens I seem to notice that boost is around 4-6 psi usually.
Anyone else ever have this? I'm thinking a bad seal from the manifold to the up-pipe, or a cracked manifold?
2004 F-350 Crew Cab LB Dually
"Longhorn Hauler" edition
New Heads!
ARP Studs
Banks Six-Gun with PowerPDA (For gauges only)
EGR Delete from IPR
Rotella ELC
New Turbo from Garrett
Gus_hauler is offline
post #2 of 3 Old 07-26-2013, 06:10 AM
Snake's Avatar
Quoted: 47 Post(s)
I agree that it sounds like an exhaust leak.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #3 of 3 Old 07-26-2013, 06:17 AM Thread Starter
Gus_hauler's Avatar
My exhaust manifolds were looking pretty nasty and pitted when I reinstalled them. If I get a used set, does it do any harm to go ahead and install the manifold gaskets?
New Heads!
ARP Studs
EGR Delete from IPR
Rotella ELC
