Need Help With Turn Signal,Hazard,Brake Lights - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-24-2013, 06:47 PM Thread Starter
5fifty's Avatar
Need help with hazard light, turn signal brake light problem.
Was on the job todaqy and had to use my hazards for a few mins. Everything worked fine for a while. Went to use my turn signal after that and nothing. No brake lights, no signals etc.
Changed one relay under dash and checked fuses.
Where should I look next. Is there any other relays that would handle these functions? If so which location or fuse number?
2005 F-550 xlt
Thanks in advance..
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #2 of 7 Old 07-24-2013, 06:50 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Turn your hazards on and then move your tilt wheel up and down and see if they start working.
dhanna6powerstroke is offline
post #3 of 7 Old 07-24-2013, 07:05 PM Thread Starter
5fifty's Avatar
Tried that already and nothing...
nothing is labeled under dash or under hood for the relays or fuses.
checked fuse 18 and 27
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #4 of 7 Old 07-25-2013, 04:27 AM Thread Starter
5fifty's Avatar
TTT
Any ideas?
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #5 of 7 Old 07-25-2013, 10:50 AM
Possibly the turn signal switch itself the light module the cluster module or just a general wire gremlin. Welcome to the world of MURPHY's LAW.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #6 of 7 Old 07-25-2013, 01:24 PM Thread Starter
5fifty's Avatar
Update. .. found the culprit. Had to dig deep in the dash to find the box that held the relay. Love my $90 Ryobi inspection scope. Would have had to pull the radio to get to it. Luckily I have a blank panel in the dash I popped out and slipped my hand in to get at relay.
For future reference the replacement part # @ Autozone is EP27 electronic flasher 2 turn signal and 6 hazard. $17.32
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
post #7 of 7 Old 07-25-2013, 01:36 PM
That one breaks a lot, use FoMoCo, it's the best and it will last a lot.
I don't know you but i don't like to get my hand inside the dash hahaha
JorgeCanek is offline
