black smoke when warm - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-24-2013, 12:23 PM Thread Starter
I am at a loss...anyone have any ides on why my truck is blowing black smoke after it warms up?
Its a 2004 F250 (late build) with 170K on it.... The only major mods are a K&N air intake, and exhaust.
The problem started awhile back with shuddering on the highway along with white and black smoke. I was getting numerous EGR codes, FICM code, injector #1 code and an underboost code. Injector 1 failed the buzz test, all others passed.
I ended up replacing injector #1, replaced the EGR cooler, threw in a new oil cooler while I was in there, replaced the EGR valve, cleaned the EBP sensor and tube, new oil (rotella T5)and oil filter-with rev-x, changed both fuel filters, and new coolant. I put it all back together and it started up and ran great.... The black smoke still didn't stop... it smokes under normal acceleration and pre-boost. Once the boost gets to about 5-6 psi, the smoke stops and it clears out.
I hooked back up and pulled the damn FICM code again...all the other codes were gone... I replaced the FICM.
Hooked up to the trailer (about 5K) and pulled it for about 20 minutes to see how it went... truck pulled like normal, no noticeable loss of power, however there was no hills or mountains I went up, but the truck is still smoking black after it gets to normal operating temp and seems to get worse as the engine gets warmer or the load gets heavier.
Now I have no codes, no CEL, injectors all passed a buzz test, cylinder contribution test checked out ok, FICM volts are showing within range.
I am out of ideas... anyone at all have any ideas as to what could be going on?
trujillo417 is offline
post #2 of 8 Old 07-24-2013, 01:09 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Looks like the only thing you didn't do is clean the turbo. Sounds like the vanes are sticking at lower boost levels.
dhanna6powerstroke is offline
post #3 of 8 Old 07-24-2013, 01:14 PM Thread Starter
I was dreading doing that... any idea on how that works? or know of a write-up anywhere on how to clean it?
post #4 of 8 Old 07-24-2013, 01:18 PM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
and that should get you going...
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #5 of 8 Old 07-24-2013, 01:22 PM
Mod Newbie
Quoted: 20 Post(s)
It's not all that difficult to do. There are quite a few YouTube videos that will help. There was a good write up on another site but they've made it to where you can't access it now.
post #6 of 8 Old 07-24-2013, 01:27 PM Thread Starter
Well the posted video is a good start.... I don't have the time this weekend so Ill probably tear into next week or the following....
thanks for the help! Ill repost when I get it done if anyone is interested
post #7 of 8 Old 07-24-2013, 01:32 PM
Mod Newbie
Quoted: 20 Post(s)
Definitely Post back
post #8 of 8 Old 07-24-2013, 01:35 PM
JUGGS's Avatar
Please do post back. Hope that clears up the problem for you.
2005 F250 Lariat CCSB/170k mi./6sp Handshaker
Don't Worry
Dieselsite coolant filter, CAT ELC, Bulletproofed and monitored by BPD
Be Happy
SCT SF3, 4" Flo Pro, 2.5" Readylift SST, 35" GoodYear Fierce Attitude M/T's
JUGGS is offline
