6.0 problems need help - Ford Powerstroke Diesel Forum
post #1 of 17 Old 07-23-2013, 09:25 PM Thread Starter
I've recently bought a 6.0 and I've had it for a about a year put 50,000 miles on it with no problems the other day I noticed it smoking alot when you would let off of it and get back in it. Then it quit, starting noticing a lot of lost power then the other day started running really rough and at 55-60 runs absolutely horrible when you rev it up on the deceleration it makes a horrible bang. Then it seems to run ok for 30 seconds or so at idle and then rough again at idle the turbo Dosent seen to spool up and if it dose it's super choppy people are telling me it's my turbo or my icp sensor but I don't wanna blow 1200 on a new turbo if my icp sensor is out someone please help me thanks
Powerstrokin321 is offline
post #2 of 17 Old 07-23-2013, 09:26 PM Thread Starter
Also isnt throwing codes
post #3 of 17 Old 07-23-2013, 09:41 PM
KCCO!!
kells17's Avatar
1. Welcome to the org! 2. What kind of mods do you have if any?
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #4 of 17 Old 07-23-2013, 09:57 PM
Ficm is what my budy found out bout my truck. Same problems
powerstroke61764 is offline
post #5 of 17 Old 07-23-2013, 10:06 PM
KCCO!!
kells17's Avatar
That was my first guess, do you have a monitor, if so, what's your numbers for your FICM?
VA Strokers
757 Diesel
kells17 is offline
post #6 of 17 Old 07-23-2013, 10:08 PM
Mine showed good on monitor but when taken off i guss it showed bad
post #7 of 17 Old 07-23-2013, 10:10 PM
Kelly i just found this out 3 hrs ago, sending it off in morning to have it rebuilt. My question is whats better 58v or 48v
post #8 of 17 Old 07-24-2013, 03:00 AM Thread Starter
It has a blue spring a 4" from the turbo back stright piped an egr delete and I have a bully dog power pup programmer but I don't have a monitor or gauges I now I need them really bad just haven't got around to it
post #9 of 17 Old 07-27-2013, 10:46 PM
KCCO!!
kells17's Avatar
Personal preference on if you want to keep it "stock" or tuned. Most get a tune put on it. Regardless what tune you get, if you have an INSIGHT, it will not show more than 50V (someone correct me if I'm wrong). So if you decide to go 58V, don't be in dismay to see it not "reading" 58V.
VA Strokers
757 Diesel
kells17 is offline
post #10 of 17 Old 07-27-2013, 10:46 PM
KCCO!!
kells17's Avatar
Any news bud?
VA Strokers
757 Diesel
kells17 is offline
