Insight cts warning reading - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-23-2013, 03:06 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
So I updated my insight cts last night to the newest version and after starting the truck this morning, I immediately got a INJPWR alert and it read 50.7. I've never seen this alert before and have no clue as to what it's trying to say, any help would be appreciated, thanks
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
post #2 of 8 Old 07-23-2013, 05:37 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
Oh And I don't know if it relates but I do have a leak somewhere and you can really hear a wooshing when it hits about 15 psi
6.0newb! is offline
post #3 of 8 Old 07-23-2013, 06:10 PM
Boozer76's Avatar
Not sure about the code on the CTS, but that whooshing sound is likely a leak in one of your CAC boots. Check them for tears around the clamps.
My Album
Currently stock engine 52k miles.
4.5" Icon lift kit
Rockcrusher front and rear diff
Procomp A/T Extreme tires
full tint on all windows
Blue Spring Update
SCT tuned, canned performance for now
Straight pipe MBRP Turbo back exhaust
XDP EGR delete kit
Boozer76 is offline
post #4 of 8 Old 07-23-2013, 06:38 PM
ngaraiderman's Avatar
Have been several threads about this new update issue. I think most just disable the alarm. Try searching on here and I bet the threads will pop up. Hope this helps
ngaraiderman is offline
post #5 of 8 Old 07-23-2013, 07:56 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
I did a quick search but didnt come up with anything, I'll try some different keywords then, and the only boot I haven't checked is the one on drivers side intercooler, do that soon, thanks so far for the replies
6.0newb! is offline
post #6 of 8 Old 07-24-2013, 06:01 AM
Boozer76's Avatar
Yup check all the boots. Mine was leaking at the passenger side inter cooler. Also check all turbo connections, especially up pipe. If you're sure it's not one of the boots or clamp connection the next spots to look are the passenger and driver up pipes themselves. If you still have egr or just used a block off plate then check the Y pipe that connects to the egr. It notoriously fails.
My Album
4.5" Icon lift kit
Blue Spring Update
XDP EGR delete kit
Boozer76 is offline
post #7 of 8 Old 07-24-2013, 03:01 PM
Quoted: 3 Post(s)
Yeah, looks like Edge added some sort of new PID called INJPWR, and by defauly it has an alarm set at <250.
So, as soon as you fire it up, your FICM Main voltage is, of course, less than 250, so it freaks out.
Took me a couple minutes to figure this one out and find the Alerts Menu to disable it.
Looks like they also messed with the EGT PID too... had to go change that as well.
Lee
ve7fet is offline
post #8 of 8 Old 07-24-2013, 05:47 PM Thread Starter
6.0newb!'s Avatar
Quoted: 17 Post(s)
Hopefully it's not a cracked bellow, I haven't touched the egr at all and never touched the turbo. Glad to know its just an edge issue though and not my truck haha
6.0newb! is offline
