gear box bolts sheared - Ford Powerstroke Diesel Forum
post #1 of 1 Old 07-22-2013, 06:34 PM Thread Starter
x148's Avatar
Just a heads up not a problem anymore. I have a 6" lift on 37" toyo mt's and the bolts holding the gear box to frame sheared off inside gear box. Had to drill them out then reverse bolts and use nuts on wheel well side and tac weld them using grade 8 bolts. Obviously the oversize tires caused this problem, just a heads up for you other guys with big tires. I also burned threw 8 PS pumps in two years haha
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
