truck chooched. p0263 and p1000 codes, fuuuuuuaaarrrrkkkk! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-20-2013, 04:17 AM Thread Starter
f350powerstroke's Avatar
truck started chooching and died. p0263 and 64 codes. started back up after 15 min and chooched its way back home, popped the hood and all 4 of my battery terminals were covered heavily in white acid ash. returned to stock ,cleaned the terminals and the codes wents away but got a p1000 code.
went for a ride and it chooched again. paid $100 to get it towed and the best part of my day i had to hear the tow driver say how much he hates 6.0's and how i should swap in a 24v cummins
paid $300 for new batteries and made it back home from the shop. still with the p1000 code. rode again this morning and it chooched and died, luckily i was near the shop and i just coasted into the garage bay nothing like driving a 1 ton truck dead on nuetral thru a city street
so should i pepper thy angus for whats to come? the p2063 is cyclinder 1 imbalance, if my injector is shot i can only afford one or two the most. im dead broke, please respond....
2007 f-350
SCT Street tune Innovative Diesel
4 inch straight pipe
Bypass coolant filter, ELC
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
REAL TRUCKS DON'T HAVE SPARK PLUGS!
Are U Aware?
f350powerstroke is offline
post #2 of 9 Old 07-21-2013, 11:13 AM
southend's Avatar
P1000 code is from the reset, the truck just has to go though a longer drive cycle. Put an injector in it and carry on. You don't have to change all eight cause one chit the bed, unless maybe you ran gas, water or dirt through your fuel system?
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 9 Old 07-21-2013, 11:30 AM Thread Starter
if i had a dirty fuel system wouldnt another code pop up for that? i hope its only 1 injector then
2007 f-350
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
Are U Aware?
post #4 of 9 Old 07-21-2013, 03:19 PM
southend's Avatar
Yea, most likely.
southend is offline
post #5 of 9 Old 07-21-2013, 03:30 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Alright Canadian
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #6 of 9 Old 07-21-2013, 06:50 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
I'm with southend on this one, replace the #1 injector and go from there. If you blew the tip off of the injector it would flood that cylinder causing your stall issue. Hopefully it is only an injector, do you have a monitor? If not you need to get one on her. Good luck and keep us posted.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #7 of 9 Old 07-22-2013, 03:51 AM Thread Starter
Originally Posted by Young-SC-Owner View Post
Alright Canadian
huh?
i have an edge ct, funny thing is the check engine light or battery light never came on in the dash. will keep everyone posted
2007 f-350
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
Are U Aware?
post #8 of 9 Old 07-24-2013, 07:36 PM Thread Starter
so guys i got my truck back today. apparently i had dirty fuel filters and had them replaced along with a bottle of diesel kleen and a fresh tank of diesel fuel. the truck has been running stock with no issues so far. i have a p1000 code so i have to keep driving her till the computer straightens itselfs out.
2007 f-350
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
Are U Aware?
post #9 of 9 Old 07-24-2013, 07:46 PM
southend's Avatar
I hope that clears it up for you. It is highly recommended to use only racor or motorcraft filters only, and make sure the caps are also oem.
southend is offline
