turbo noise??? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-19-2013, 06:59 PM Thread Starter
turbo noise???
this is weird......
i have an 05, 70,000 on my 6.0, the past several months this has happened half dozen times. Sometimes when I trailer and do not have to tow/haul in gauged this happens..when I accelerate and let off I am getting a rattle coming from the turbo, or thats what it sounds like but not 100% sure, I seem to lose turbo psi when this happpens and it does not want to shift or it shifts at a high rpm, this just happens for maybe 1 mile and goes away.
This has not happened to me when Im trailering and the tow/haul is in gauged before i start driving,and it has not happened at all just driving the truck with nothing in tow.
I bought this truck new in 2005 and everything is stock
Please help, thank you!!
Brian74 is offline
post #2 of 9 Old 07-21-2013, 12:41 PM Thread Starter
anyone???????
Brian74 is offline
post #3 of 9 Old 07-21-2013, 12:55 PM
juzatheman's Avatar
Hi if i understood right then its sounds right about normal...
I can make that sound when ever i like if accelerate up hill even without load and after creating some boost let off the gas it does that "turbo fart"
juzatheman is offline
post #4 of 9 Old 07-21-2013, 11:19 PM
KingStroker70's Avatar
Is it a rattling like metal on metal type sound? Is the turbo at full song (boost) when you let off the throttle?
KingStroker70 is offline
post #5 of 9 Old 07-21-2013, 11:50 PM
juzatheman's Avatar
No not realy maby 10-15 psi when it start to do that but i dont have metal kind of sound.
post #6 of 9 Old 07-22-2013, 06:50 PM
The turbo will make a sound like a bursts of air when its up in full boost and you take your foot out of it once or twice with the stock box. Its more present with after market intakes. Its hard to say if its normal or not with out actually hearing it. It might be worth it to get a mechanic to ride along with you if you can duplicate the sound for them. Sorry I'm not really any help here.
post #7 of 9 Old 07-22-2013, 08:03 PM
x148's Avatar
Check the three bolts that hold the turbo to the pedestal, then check the 4 bolts that hold the pedestal to the engine. If all those bolts are tight then it would lead me to believe maybe something in the drive train is banging like u joints, or if you tow a lot check the leaf springs to see if they are broken. I had a customer that towed excavators almost daily and had a banging sound at take off or anytime he hit the throttle kind of hard, turned out both rear leaf springs had a broken leaf in the middle which was causing that sound.
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
post #8 of 9 Old 07-23-2013, 06:08 PM Thread Starter
Saw a ford mechanic today, looks like i just need to clean my turbo, he said its the veins in the turbo, most likey some rust in it he said due to the fact that the truck is driven once maybe twice a week.
Brian74 is offline
post #9 of 9 Old 07-24-2013, 06:27 AM
x148's Avatar
Veins and unisom ring, just clean it yourself its so easy a blonde could do it.
05 F350
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-Pro Comp Trac Bars
x148 is offline
