05 6.0 Rough Start then died - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-19-2013, 06:47 AM Thread Starter
I have a 05 6.0L, 4" Exhuast, QT Looney Tune, Edge CTS.
Left for work this morning, grabbed breakfest, turned the truck off, went to start it back up and it had a rough start then died. The ICP PSI was around 250-300, NO CEL at all during any of this.
Spent some time checking on things(30mins), took the tune off, tried to start the truck with it's stock programming and it turned over a little rough and then evened out. Ran home, put the QT Looney tune back on and started the truck without an issue. Drove to work, turned the truck off and started it again, since it was now hot and it turned over.
I hate to take it in to the shop with it now showing any signs.
Hoping someone can help!
2005 Crew Cab XLT FX4
MBRP 4" Turbo back cat delete
Edge Insight CTS
SCT X3 w/Looney Tune
mabner is offline
post #2 of 2 Old 07-22-2013, 07:13 PM
x148's Avatar
Seems like you got a high pressure oil leak somewhere, my guess would be STC fitting if your truck has one, or stand pipe/dummy plugs seals are worn.
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
