I need it fixed!!!! I will paypal whoever gets it right - Ford Powerstroke Diesel Forum
post #1 of 59 Old 07-17-2013, 05:46 PM Thread Starter
Ok, just giving everyone a head start. Got the truck back today and they said oil cooler. so if anyone has seen my other post about "cooling issue" it has alot of my info in it about my problem but to bring it all up and quick like. The truck is NOT over heating but not running at operating temp. I can drive no load at 65mph ECT will be around 224 and EOT 216-220 EGT is around 850-900ish. I can let the truck sit over night. Start it up, both ECT, EOT will be 88 or 89, same temp. Then i drive the truck and my ECT will climb at a normal-ish rate but within a matter of 5 miles the ECT will be up around 215 and oil is still climbing fairly slow around 185ish. I can floor the truck and it will get up around ECT 225-230 and EOT will be around 200, obviously working it's way up too. Both topping out around the first set of numbers i wrote at 65mph. I can come to a stop from 65mph and the ECT will drop down quickly to like 212-214 and the EOT will be up around 220-221.
The truck has new waterpump, radiator, coolant temp sensor, thermostat, degas bottle cap, CAT ELC coolant, vacuum filled, and was flushed prior to that. I'm at a lost right now with the truck and it seems like I am not ever going to get it fixed. Before I dig into doing a oil cooler I wanted to see how many people here say the same. The truck never pukes coolant, has arp studs with oem headgaskets and never gives any symptoms of a headgasket issue. Just my ECT, EOT temps are higher than normal op temps should be for no load. I could understand these temps if I were towing a 10k trailer up a mountain or something. Thanks.
Chris.
Strokinslow is offline
post #2 of 59 Old 07-17-2013, 05:55 PM
Quoted: 370 Post(s)
Feedback Score: 5 reviews
I don't think it's your oil cooler!!!
Why, because its your Coolant temp that's the issue... Not the oil temp per se.
I think it's your fan clutch
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #3 of 59 Old 07-17-2013, 05:57 PM
Quoted: 370 Post(s)
You should be able to diagnose it with a good scanner.. Like an AE or at a shop with a good expensive scanner that they can command the fan what to do!
Studded and Deleted
post #4 of 59 Old 07-17-2013, 06:01 PM Thread Starter
Just got in it and drove it to a store close by (3 miles) and when I started the truck is was still warmish from previously driving it. ECT was 159 EOT was 158. Got goin and ECT got up to 226 and EOT was 189. Got to the parking lot and within 2 mins of just idling, ECT is at 202, and EOT 195.
Chris.
post #5 of 59 Old 07-17-2013, 06:02 PM Thread Starter
Fan is coming on for sure, right at 214.
post #6 of 59 Old 07-17-2013, 06:03 PM
Quoted: 370 Post(s)
Your oil looks perfect! No way is it your oil cooler!
But your coolant.... You got enough antifreeze in there?
Studded and Deleted
post #7 of 59 Old 07-17-2013, 06:04 PM
Quoted: 370 Post(s)
Fan could be coming on at 214 but still be failing where you need it.... 190-214.
Studded and Deleted
post #8 of 59 Old 07-17-2013, 06:12 PM Thread Starter
For sure the amount of coolant is correct. This engine also used to be in a F-350 dually and it never gave the previous owner any issues with ECT or EOT so he claims. I.E. it has all the same oil cooler, head gaskets etc.. Just pulled from his truck and put in mine. I'm lost.
Chris.
post #9 of 59 Old 07-17-2013, 06:59 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1707 Post(s)
EGR delete or not? and what year truck are we delaing with?
toren302 is offline
post #10 of 59 Old 07-17-2013, 07:00 PM Thread Starter
Egr is deleted, 2005 truck with a 06 motor.
