Terrible fuel mileage 05 6.0L - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-15-2013, 08:20 PM Thread Starter
Here is what is done to my truck: h-11 studs, RCD EGR delete, brand new oil cooler, sinister coolant filter, s&b intake, 4" dual straight pipe, SCT livewire TS with looney wild from Vivian, blue spring upgrade.
PROBLEM: I only get about 13.5 mpg, usually less, with cruise set around 75 and only slightly hilly driving. I haven't had time to test injectors yet, but what else could it be?
I run T-6 full synthetic with archoil, and have a 4.5" lift with 35s.
I feel like I should get way better mileage than that. Any input would be great.
gleason51 is offline
post #2 of 16 Old 07-15-2013, 08:59 PM
Has the mpg suddenly dropped? Like recently you noticed it, and it had been better prior to this?
Any other symptoms like more smoke, etc?
Partychief67 is offline
post #3 of 16 Old 07-15-2013, 09:06 PM Thread Starter
Ive only owned it for a few months. Maybe i just didnt check it out well enough before i bought it. Mileage has always been poor but i hoped after the new tuner with custom tunes, new exhaust, and new oil cooler that it would get better. Truck does smoke white a little upon start up sonetimes, and can idle/run rougher when cold. More black smoke than before, but i figured that was the exhaust and tunes. All I can think is injectors. But would that kill my mileage that much? I have buddies with 6.0s getting 17-19+
post #4 of 16 Old 07-16-2013, 12:59 PM
That mileage doesn't sound too terrible to me. It may be a little low but with 35's and a lift...that might be where you'll sit. Mine is an FX-4 lifted a couple inched with 315's (33's) stock other than blue spring, coolant filter, egr delete and I avg about 15.
I have found it doesn't take much to get the mileage to drop to 13.5-14. Got 16 once on a long trip cruise set at 62
Chuck Norris once visited the Virgin Islands, they are now known, simply as, The Islands
sixoh is offline
post #5 of 16 Old 07-16-2013, 03:49 PM Thread Starter
Now the trip this morning was 11.4 mpg. I did cruise along a little faster today but damn that's terrible
post #6 of 16 Old 07-16-2013, 06:37 PM
I was getting poor mileage when my ficm was going out. Might be worth checking the ficm voltage..
darenative is offline
post #7 of 16 Old 07-16-2013, 06:46 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
same here. When my ficm was bad I got mpgs between 9 and 13
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #8 of 16 Old 07-16-2013, 06:56 PM Thread Starter
Ficm voltage from the livewire 48-49 volts.
post #9 of 16 Old 07-17-2013, 03:16 PM
When? First thing in the a.m. or after you drive 20 miles?
post #10 of 16 Old 07-17-2013, 03:34 PM Thread Starter
It pretty much is always right around that voltage.
