Turbo not boosting over 16 psi - Ford Powerstroke Diesel Forum
post #1 of 18 Old 07-14-2013, 07:30 PM Thread Starter
Boozer76's Avatar
I've been regularly seeing 24-26 psi on full throttle, however recently it's only going up to 16/17 tops. My turbo was replaced just before I bought the truck a year ago and it's my daily driver so I'd be a little surprised that vains are sticking this soon. No hissing noises or noticeable leaks anywhere. Am I due for a turbo servicing or are there other things I can eliminate first? I have an Edge CTS monitor and other than boost all numbers have been normal.
My Album
Currently stock engine 52k miles.
4.5" Icon lift kit
Rockcrusher front and rear diff
Procomp A/T Extreme tires
full tint on all windows
Blue Spring Update
SCT tuned, canned performance for now
Straight pipe MBRP Turbo back exhaust
XDP EGR delete kit
Boozer76 is offline
post #2 of 18 Old 07-14-2013, 08:06 PM
RetiredFD's Avatar
Has it been sitting for a while?
- Chris
2006 F250 CCSB Lariat
RetiredFD is offline
post #3 of 18 Old 07-14-2013, 08:55 PM Thread Starter
Boozer76's Avatar
Nope, it's my daily driver.
My Album
4.5" Icon lift kit
Blue Spring Update
XDP EGR delete kit
Boozer76 is offline
post #4 of 18 Old 07-14-2013, 10:55 PM
DieselnDrums's Avatar
Whats the psi just with normal driving? Do you hear anything different from the turbo or engine in general when you hit the higher rpms? I ask cause you might have a very small leak somewhere on the intake system or the exhaust up pipes and is only noticeable when you get on to it.
06 f350, 6.0, 5 torqshift, egr delete, replaced oil cooler, SCT tuner, Head studs, MTW St 1 billet wheel, Custom tunes from GH.
DieselnDrums is offline
post #5 of 18 Old 07-15-2013, 04:30 AM Thread Starter
Boozer76's Avatar
Good question, I did have a leak in the up pipe a few months back after an egr delete. It hissed pretty bad, but it killed the low end boost. It was a dog until you get on the throttle and the would go up to the 24-26 range, the exact opposite of now. This time it's the opposite. It's completely normal when driving normally. Turbo spools up quickly, it just won't go over 16/17 psi no matter what.
My Album
4.5" Icon lift kit
Blue Spring Update
XDP EGR delete kit
Boozer76 is offline
post #6 of 18 Old 07-15-2013, 05:46 AM
Sounds like an underboost problem, have you changed your exhaust back pressure sensor lately?
powerstroken00b is offline
post #7 of 18 Old 07-15-2013, 06:16 AM Thread Starter
Boozer76's Avatar
No I haven't. I thought this could be the culprit as well, but I've been a little confused because I have read a few threads that said the EBP seonsor was rendered useless with the latest flash. My turbo does cycle at idle when it's cold (hear the turbo spool slightly at idle, then the exhaust note changes to low rumble for a second or 2)so I know I have this flash. I didn't want to tear into it if it's not necessary. I also have no codes thrown as well.
My Album
4.5" Icon lift kit
Blue Spring Update
XDP EGR delete kit
Boozer76 is offline
post #8 of 18 Old 07-18-2013, 10:31 AM Thread Starter
Boozer76's Avatar
I am going to clean out the EBP sensor and tube this weekend, no one has any other thoughts as to what it could be?
My Album
4.5" Icon lift kit
Blue Spring Update
XDP EGR delete kit
Boozer76 is offline
post #9 of 18 Old 07-18-2013, 11:48 AM Thread Starter
Boozer76's Avatar
And one other potentially stupid question. I deleted my EGR back in the winter, however I left the EGR valve in and still plugged in. I heard that disconnecting it could lead to issues with the fan cooling system and that it's better to just leave it in. Having said that, do I still need to clean the valve periodically?
My Album
4.5" Icon lift kit
Blue Spring Update
XDP EGR delete kit
Boozer76 is offline
post #10 of 18 Old 07-19-2013, 07:23 AM
I don't think you would need to clean the egr valve after you deleted the cooler. But definitely keep plugged in, cause like you said you will have problems with your fan not engaging at the proper times with it unplugged. As far as the ebp sensor I have heard a dozen guys say that it's still acive, and a dozen guys say that it's inactive. From what I have read it's the 03 to 04's with the 06e17 flash are the ones that use the inferred inputs and cancel out the ebp sensor. As far as I can tell the 05+ still might be using a reading from the ebp, but it's possible that a new flash could be out there that cuts out the signal from the ebp. I guess to know for sure you'd have to hook up a scangauge
