White smoke at start up? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-12-2013, 03:59 AM Thread Starter
This is my first diesel and have noticed quite a bit of white smoke till it gets up to temp? I don't know if that's normal or?? It has the egr delete. Another thing, it takes so long to get up to temp, it is really a dog till it warms up as I have no power.
cschip is offline
post #2 of 6 Old 07-12-2013, 06:16 AM
ps_lane01's Avatar
Quoted: 7 Post(s)
Any other issues? Does it spit and sputter when cold? What oil are you running? any DTC? You could have an open injector spitting loads of fuel into the engine. Could be burning coolant too.. Whats your delta temps when warm?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #3 of 6 Old 07-12-2013, 01:05 PM Thread Starter
Yea it spits and spudders for about 3 miles then stops. And the white smoke stops too at about the same.
cschip is offline
post #4 of 6 Old 07-12-2013, 01:33 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
Alot of white smoke or barely noticeable? Any DTCs? contribution codes? I would be careful, if you have an injector hung open u could litteraly melt the piston and destroy ur engine. As much info as possible would be great
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #5 of 6 Old 07-13-2013, 06:29 PM Thread Starter
Barley noticeable, it's not thick. You think injectors?
cschip is offline
post #6 of 6 Old 07-15-2013, 03:46 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
Well if you jumped to conclusions too fast you could spend alot of money on something that could be as easy as running revx in the oil or even a oil change. Do you have a scan tool? I have the sct livelink and that will get alot of basic PIDs to monitor during sticky situations such as this, you will atleast be able to rule out things that are ok.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
