Advice on Stuck Fuel Reg Flare Nut? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-11-2013, 08:31 PM Thread Starter
Hey all - top flare nut for the fuel inlet line on fuel bowl is stuck something fierce. Don't have a line/flare wrench (every damn store in town is out) - just using a couple of box wrenches, but I'm about to either strip the flare nut or twist/crack my fuel line if I torque on that thing any harder. Been hitting it with PB, and a few light taps with a ball peen but still nothing. Advice?
Current: 2004 Excursion Ltd Eddie Bauer
115,000K and counting
Blue Spring
New Oil Cooler @ 113K
Filters every 5
Past: 1996 F250HD 7.3 IDI 276K
dieselgman is offline
post #2 of 7 Old 07-12-2013, 06:21 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
If you really need to get it off, you may have to replace more than you want to! Unfortunately, if it was installed too tight or corroded/fused it will require way more force than needed and could easily take the fuel tube with it.
If you are just going in for the blue spring, you can leave it attached and just remove the cap screws. You would then just lightly pry to separate the pressure regulator from the fuel bowl to replace the parts. Beware of loosing any parts as you work in the small space.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 7 Old 07-12-2013, 06:47 AM Thread Starter
In addition to the blue spring, what I really need is the space to get at the thermostat housing bolt that sits right under the fuel line. The last tech to work on this thing partially rounded it off and didn't use any anti-seize so it's stuck in there really well. Worse case scenario is get the pliers and pull it out but given how little space there is to work with I'd prefer to just get the fuel line out of the way.
Of course I could just cut the line and splice in a new flare connector.
Blue Spring
Filters every 5
post #4 of 7 Old 07-12-2013, 05:08 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
I never use flare nuts on those. It'll come but you're really going to have to lean on it.
7/8s jammed over top of the rad hose is about the only spot you can get a back up wrench on the fitting. push on it at the same rate you're pulling on the 13/16" line nut. Sometimes you can get the wrenches lined up just right so you can squeeze both in your hands like a pair of scissors.
Just Be glad it's not an econoline, as hard as that seems e-series is a little harder
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 7 Old 07-12-2013, 06:14 PM
Quoted: 43 Post(s)
Been there done that a few times over the years.
Frank
Working for Toys
post #6 of 7 Old 07-12-2013, 06:37 PM
RetiredFD's Avatar
I did get a very slight twist on my fuel line when I did my blue spring. No problems so far thought. I was prepared to replace the whole line and it finally broke free.
- Chris
2006 F250 CCSB Lariat
RetiredFD is offline
post #7 of 7 Old 07-13-2013, 08:44 PM Thread Starter
Ended up taking the FPR cover off for the blue spring update, then just unscrewing the cover. Tried the scissors trick but nada. At some point in the future I'll go back and fix it but for now too many things to do.....like fetch that long socket that dropped in my engine valley!!
Thanks for the tips all.
Blue Spring
Filters every 5
