Help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-09-2013, 09:42 AM Thread Starter
Help
Hello all
I test drove a 2003 with the 6.0 last night it has the mid level bullydog
programmer installed it seemed like it was running a little rough when I would hit
the gas almost like it was getting bogged down the guy said it is probably
the programmer needing to be reset. Is this a common issue does this sound like
that is the problem or is there something more serious? I am new to diesels
please heeeellllllppppp
Thanks in advance
stevebrule is offline
post #2 of 8 Old 07-09-2013, 09:58 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 2 Post(s)
there is probably more to it than that , im not a fan of a bully dog on a 6.0 , but I doubt updating the tuner is gonna fix a driveability issue
ITS STOCK
SCUFFY828 is offline
post #3 of 8 Old 07-09-2013, 10:01 AM Thread Starter
So you dont think a faulty programmer could cause it to bog down when I accelerate?
What do you think would cause that?
post #4 of 8 Old 07-09-2013, 10:03 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 2 Post(s)
sticking turbo, egr valve , icp sensor , fuel pressure , oil pressure , the list goes on , that's real hard to say what that is
ITS STOCK
post #5 of 8 Old 07-09-2013, 10:07 AM Thread Starter
Wow all kinds of options thanks for your input
post #6 of 8 Old 07-09-2013, 10:10 AM
turbotibbo's Avatar
i would stay clear of that truck imho . read up on the stickies in the general 6.0l section
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #7 of 8 Old 07-09-2013, 04:35 PM
Quoted: 858 Post(s)
Feedback Score: 3 reviews
Originally Posted by stevebrule View Post
Hello all
programmer installed it seemed like it was running a little rough when I would hit the gas almost like it was getting bogged down the guy said it is probably
Thanks in advance
How many miles are on it? If you can, get an oasis report.
With you being new to diesels you may want to steer clear. Lots of variables though.
1. How mechanically inclined are you
2. What's your budget
3. What's the purpose for the truck
4. Do you personally know a friend that is well versed in the 6.0's to help you out.
The 6.0 really can be a great engine, but its definitely not a truck for someone with no experience on wrenching on cars let alone a diesel. But, if your used to wrenching on all your stuff and if you can get it for a good price then jump on it.
Corey@CNCFAB is offline
post #8 of 8 Old 07-11-2013, 12:09 PM Thread Starter
Hello thanks for all the advice it only has 78,000 miles it was a former sema show truck it does not get driven very much at all im not great at working on cars but my girlfriends brother is a very good mechanic
thanks
