Lopey idle problem - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-09-2013, 06:50 AM Thread Starter
ps_lane01's Avatar
Quoted: 7 Post(s)
Lopey idle problem
For the past few days it sounds like i have a bad lope like a dead or sticking injector. This is what im seeing...
Ive got 60 psi fuel pressure (goes right up when key on and stays there)
icp des is 4.4
Icp actual is 4.39-4.41
Ipr is .23
No codes at all even though its shaking the truck and should be throwing a balance or contribution code. Where should I go from here? I dont want to spend 195 dollars for diesel diagnostics from the local dealer. Do i have to invest in AE?
Thanks!
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #2 of 7 Old 07-09-2013, 07:13 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
icp des is 4.4
Ipr is .23
Thanks!
take a multimeter and check the voltage off of your FICM and see if thats whats screwing you up.. invest in AE anyway X-D and how does your truck behave when driven?
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #3 of 7 Old 07-09-2013, 07:25 AM Thread Starter
ps_lane01's Avatar
Quoted: 7 Post(s)
I checked ficm 6 months ago, its a reman 4 screw 05' + thats was time stamped 2010 probably time to check that again tho.
Has a turbo overboost/ compressor surge problem but no codes for that either.. Other then that drives fine. Had two injector contribution codes 8 months ago revx cleared that up
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #4 of 7 Old 07-09-2013, 07:27 AM Thread Starter
ps_lane01's Avatar
Quoted: 7 Post(s)
Thanks for help, it also starts really slow My optima starting batteries check out fine
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #5 of 7 Old 07-11-2013, 08:29 AM Thread Starter
ps_lane01's Avatar
Quoted: 7 Post(s)
Ficm is 47 starting and 48.5 running
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #6 of 7 Old 07-11-2013, 07:52 PM Thread Starter
ps_lane01's Avatar
Quoted: 7 Post(s)
http://youtu.be/bxOGvLB1u3Y
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #7 of 7 Old 07-12-2013, 11:04 AM Thread Starter
ps_lane01's Avatar
Quoted: 7 Post(s)
Now my secondary billet aluminum fuel filter cap is puking from the threads!! Someone help pleasseee
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
