-PLS HELP, Battery light is on - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-09-2013, 04:59 AM Thread Starter
Morning all, I'm needing some assistance
I bought two new batteries from local Ford Dealership two years ago...they both died over the weekend and were under warranty.
After the two new ones were replaced and a day later, the battery light is still coming on.
So I went to O'Reilly's to have them test the batteries and the alternator while it was running and they both test out ok. Bout 58amp at the batts from the alt (again while running)
The light comes on intermittantly...sometimes it stays on a for a minute or two, sometimes longer but I'm stuck as to what it could be ??
We have a big trip were taking this weekend (towing the boat to a cabin 4 hours away) and the last thing I need is to worry it wont start!
Thanks in advance
Steve n' Tammy
05' F250 Crew Cab Harley Davidson
8 inch Fabtech kit-38 inch Mickey Thompson ATZ's-20 inch Moto Metals-EGR Delete-ARP'd-O Ring Heads-Full exhaust-Chipped-Baja spare-Recon Big Rig ICE and Back up
stevenc1 is offline
post #2 of 14 Old 07-09-2013, 08:04 AM
Quoted: 780 Post(s)
The voltage regulator is starting to go. Its just a matter of time. Fwiw, if you buy an autozone or O'Reillys you may go through 2-3 before you get a good one.
Alternator, that is.
Corey@CNCFAB is offline
post #3 of 14 Old 07-09-2013, 08:52 AM
ADMIN AND TECH
SCUFFY828's Avatar
exactly what he said , heck I have replaced several ford reman ones lately , cant buy good stuff , sad but true
ITS STOCK
SCUFFY828 is offline
post #4 of 14 Old 07-09-2013, 12:22 PM
Quoted: 780 Post(s)
Unless you buy a DC Power alternator. :thumbup:
post #5 of 14 Old 07-09-2013, 12:45 PM Thread Starter
Hmm...so ya'll think this is the problem? And, if so...should I get one at the Ford Dealership or somewhere else?
Steve n' Tammy
stevenc1 is offline
post #6 of 14 Old 07-09-2013, 12:56 PM
Quoted: 780 Post(s)
Your only going to pay slightly less for a new one at the dealer than this.
https://www.dcpowerinc.com/fit/2000~...6-185-oem.html
post #7 of 14 Old 07-09-2013, 01:32 PM
ADMIN AND TECH
SCUFFY828's Avatar
the ones I have had some decent luck with is the 140 amp alternator o-reillys sells , cant remember the price right this sec , but with a couple customers with repeat alternator issues ive tried that one and haven't seen them back for that problem anyway
ITS STOCK
post #8 of 14 Old 07-10-2013, 05:03 AM Thread Starter
...wait, I'm getting a bit confused. Is it the voltage regulator or the alternator?
Steve n' Tammy
stevenc1 is offline
post #9 of 14 Old 07-10-2013, 05:07 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
the voltage regulator is in the alternator
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #10 of 14 Old 07-10-2013, 05:10 AM Thread Starter
It's not external as it used to be in older set ups?
Steve n' Tammy
stevenc1 is offline
