2003 6.0 died, towed home, where to start? - Ford Powerstroke Diesel Forum
post #1 of 26 Old 07-07-2013, 01:41 PM Thread Starter
so I have a 2003 6.0 with 240k plus miles, while driving to the parts store to get front sway bar bushings....for this truck it died and would not restart.cranks fast and fine, seems to want to fired but does not. no smoke from exhaust while trying to start.
some history: heads were done 80k or so ago, injectors as needed, just did another ICP,DIY FICM repair a few years back. I am on the original HPOP, turbo,
any ideas on where to begin
JAYINH is offline
post #2 of 26 Old 07-07-2013, 02:05 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Do you have any monitor on the truck by anychance?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 26 Old 07-07-2013, 02:52 PM Thread Starter
I don't,just a hand held tundra
JAYINH is offline
post #4 of 26 Old 07-07-2013, 02:53 PM Thread Starter
Tuner
JAYINH is offline
post #5 of 26 Old 07-07-2013, 04:41 PM Thread Starter
probly going to grab a scan gauge 2 in the AM to monitor ICP, FICM VOLT, IPR and sync. I was poking around under the hood and found a large tear in the turbo elbow boot. truck started to fire while cranking when cool. not like a hot start scenario tho, just better than when I was n the side of the road.
JAYINH is offline
post #6 of 26 Old 07-07-2013, 04:47 PM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
it might be STC fitting or something leaking if it starts to fire cold but doesn't even start warm, unless i misunderstood.
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #7 of 26 Old 07-07-2013, 04:53 PM Thread Starter
I had the no hot start issue a few months back, tore into it with the parts for the STC fiting and my 03 has the old style HPOP fitting.....it looked good at the time.
JAYINH is offline
post #8 of 26 Old 07-07-2013, 08:23 PM
Maxium4x4's Avatar
No Snap To Connect fitting on the 2003 6.0L engine... Did you check for any codes? Few ideas to for you to look at, Battery voltage, pull the IPR and check the screen. The FICM is 2 halves, so check and see if you are showing 48 volts while cranking. Do not throw parts at it, also one last thing, any fuel in the truck? 240K miles on the clock, the high pressure pump may have up and died.
Maxium4x4 is offline
post #9 of 26 Old 07-07-2013, 08:40 PM Thread Starter
scanned for codes and got 2 injector codes, cont/bal..bad injectors I assume. will check FICM voltage in the AM after purchasing scangauge 2 . yes to fuel. is the IPR hard to pull out? I will be in there tomorrow and can pull it also. I would not look past the HPOP also...it lasted this long but your right, it may have died. is there a better place other than ebay to scoup up a HPOP for the 03's. is there a place that does rebuilds?
JAYINH is offline
post #10 of 26 Old 07-07-2013, 08:47 PM
Maxium4x4's Avatar
Thinking the lower shell on the FICM died, so do not get in a hurry until you find out more of what you have and do not have. Ebay is not my choice for parts....
