Loss of power and fuel economy. Plus slightly higher Turbo psi. - Ford Powerstroke Diesel Forum
post #1 of 19 Old 07-07-2013, 06:34 AM Thread Starter
Quoted: 4 Post(s)
I have a 2004 with 200k miles on it and recently I have noticed a sudden decrease in fuel economy and acceleration is poor at times. I replaced injectors at 196k and my FICM is normal voltage (46-48v). I really don't know what coul be causing this. I took it in for a service and they saw the EGR valve was bad so they cleaned it and we unplugged it an i started running stanadyne formula in my fuel and I began getting 23mpg highway. Well that lasted about 2 weeks and then my mpgs slowly began decreasing and my turbo psi was increasing. Just last night I filled up and calculated my mileage and I got 15.1 mpg. Well that's too low and I need to do something. At first when all this was happening I took it to a transmission shop and they said they heard something internal and sounded serious. I later heard this shop gets sued quite often so I took it to 2 other shops and they said everything was normal. And that's what made me think it was engine related but I don't know what it could be.
My symptoms are a very loud idle, loss of fuel economy, and higher turbo boost with a sputtering sound. Also no exhaust smell in the cab which is good.
Anyone know what could be causing this?
joejack6.0 is offline
post #2 of 19 Old 07-09-2013, 10:46 AM
Maybe a video would help with "sputtering sound" and "loud idle", it's tough to tell what you mean without hearing it.
I'd start with easy stuff. Do you have a monitor...
Check your engine load, maybe it's a simple as a sticking break caliper. Extra drag makes you work harder to maintain speed=drop in MPG and more boost.
Any smoke or anything else out of the ordinary or just what you've described already?
2005 - Excursion - Eddie Bauer - 4x4
185amp DC Power Engineering alternator
BPD oil cooler and cold weather package
Updated standpipes and dummy plugs
Edge Insight CTS with fuel pressure
No more STC fitting in the HPOP
Updated fuel pressure spring
Updated turbo oil drain
Updated turbo oil feed
Sinister Coolant Filter
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
The best 6.0 advice I've ever seen...
Fishermedic is offline
post #3 of 19 Old 07-09-2013, 03:18 PM Thread Starter
Quoted: 4 Post(s)
Yes I have a Scangauge II. What is the normal load percentage for a truck not towing? And I haven't seen any smoke.
post #4 of 19 Old 07-09-2013, 04:06 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Fuel filters or type of fuel. My truck does not like murphy diesel it will run like junk and kill my mpg. I run exxon in my rig.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #5 of 19 Old 07-09-2013, 04:48 PM
Now i noticed before i pulled the turbo to clean it that it would boost like 40 psi. Almost like it would stick. Do you have something to pull codes because the scangauge wont pull codes on my truck. It could be a brake caliper locking up like mentioned above but your caliper would be hot to the touch like on fire. Just a thought good luck.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #6 of 19 Old 07-09-2013, 05:08 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
Joejack6.0 im in the same exact boat as you... Except 10 miles per gallon 12 highway.. Interested to see where this goes..
Bluedemon i pulled my turbo, cleaned it, put a video on here of the vgt working correctly, did a vgt relearn and im still getting 35-40 psi boost and horrible compressor surge. Did i mess something up? Not trying to derail your thread o.p.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #7 of 19 Old 07-09-2013, 05:09 PM Thread Starter
Quoted: 4 Post(s)
I'm not sure who supplies my fuel. They only have my service station on KY and IN. I go there almost every week so I doubt that's the problem.
post #8 of 19 Old 07-09-2013, 05:13 PM
Does your Degas bottle have excessive pressure or puking?
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #9 of 19 Old 07-09-2013, 05:17 PM
Fuel filter dirty will kill mpg, do you have a fuel pressure gauge? Blue spring update?
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #10 of 19 Old 07-09-2013, 05:18 PM Thread Starter
Quoted: 4 Post(s)
Did you check EGR valve? They determined mine was bad and it was doing the same before then they cleaned it but they suggested I replace it.
