NEED HELP - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-07-2013, 06:00 AM Thread Starter
pillsbury's Avatar
NEED HELP
I pulled out to pass a semi truck the other day on the interstate. When I got on the gas and the turbo spooled up instead of the truck taking off it started making a hissing sound. It sounds like that air blowing out of a air compressor. It only does it under a load. I put a load on it and got to listening to it. I comes form the air breather. Any ideas? I pulled the breather off the turbo and the fins have a little play in it. Thanks in advanced for all the help.
gary
mbrp 5" turbo back stright piped exhaust 6" tip
airaid cold air intake
ARP Head Studs
superchip
pillsbury is offline
post #2 of 7 Old 07-07-2013, 06:06 AM
KCCO!!
kells17's Avatar
Did you still have power for the pass or did you lose boost psi? Could be exhaust leak in y-pipe?
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #3 of 7 Old 07-07-2013, 06:20 AM Thread Starter
pillsbury's Avatar
Had some power, but not like it should.
ARP Head Studs
superchip
post #4 of 7 Old 07-07-2013, 06:52 AM
KCCO!!
kells17's Avatar
I would check the y-pipe first...see if there is soot back there on the firewall. If all is clear there, check turbo intake tube...if you still have the OEM silicon (sleeves) on your intake...very well could be one of those has split...
VA Strokers
757 Diesel
kells17 is offline
post #5 of 7 Old 07-07-2013, 03:58 PM Thread Starter
pillsbury's Avatar
I will check that. Now my power steering is acting up. No low speed I have no power steering. Not sure if they are related or not
ARP Head Studs
superchip
post #6 of 7 Old 07-07-2013, 04:47 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Check intercooler boots!! I had the same issue and my lower intercooler boot was loose. Tightened it back up and i had all my boost back.
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #7 of 7 Old 07-07-2013, 04:49 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
or it could be a cracked boot it may be loose or cracked. or there is a crack in the y pipe flex pipe area
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
Tags
no power , turbo 6.0
