Fuel Pressure Problems - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-03-2013, 09:11 PM Thread Starter
Mud digger's Avatar
Alright guys, I'm starting to lose my mind. Today I installed the blue spring upgrade and my EV2 fuel pressure gauge. I installed the blue spring first so I don't have a previous reading of my fuel pressure . When I start the truck the fuel pressure only goes up to 37, and kinda bounces up and down between that and 39. I would like to hope that my fuel pressure is a hell of a lot higher than that especially after the upgrade. The truck has been and is still running great. I took it for a drive and a full throttle for a split second it actually jumped up to almost 50psi. What in the world is going on here? Has anyone else had a problem like this?? Thanks in advance
David
2004 F-250 CCSB 4x4- Sinister Coolant filtration system, CCV reroute, 5" Flo-Pro Exhaust with a 6" MBRP tip, SCT Livewire TS
Mud digger is offline
post #2 of 6 Old 07-03-2013, 09:13 PM
Sounds like possibly some air trapped in the line going to the sending unit for your gauge if its bouncing around alot. Just my two cents but I'd keep an eye on it to see if it gets any better after a few days.
"the C4 6.0" 2004 F350 srw lariat CC
ARP's, Liberator fire ringed heads, EGR delete, Brute Force CAI, 6.4 banjos, blue spring, cfm+, Livewire TS custom tune, 5"turbo back with 4" down pipe. Cowel Hood. Lifted on 35's. Suncoast tranny. Newly added 05 grill and harley headlights.
Amfw119 is offline
post #3 of 6 Old 07-03-2013, 09:16 PM Thread Starter
Mud digger's Avatar
That's kind of what I was hoping for but I bled the line going to the sender and I still get the same results.
David
post #4 of 6 Old 07-03-2013, 11:46 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Did you tap on the gauge… maybe it's faulty? Ive seen this several times(not with the ev2 though)
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 6 Old 07-04-2013, 12:04 AM Thread Starter
Mud digger's Avatar
Well I couldn't take it any longer so I tore the truck back apart and pretty much reinstalled the kit again and now I'm seeing the FP where it should be, around 63psi. I never saw anything out of place and everything seemed nice and tight. No idea what could have caused this but I'm happy it's fixed now.
David
post #6 of 6 Old 07-04-2013, 11:49 PM
Quoted: 8 Post(s)
If its fixed now, I'd assume it was due to air in the lines. Glad you got her fixed though!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
