P0299, turbo noise and deltas - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-03-2013, 07:06 PM Thread Starter
2005 Excursion 6.0L PSD, 102K miles, stock as far as I know.
EOT/coolant delta approaching 15* at 65mph on the highway, throwing P0299 when towing my RV, and there's a noisy spin-down of the turbo when I shut the engine off.
So I'm thinking about pulling the turbo off & cleaning it, along with the EGR valve - but my research (in places like this forum) says I may have to replace the turbo.
Was looking at the Garrett replacement turbo and was wondering if I can really just bolt it on, or do I need to beef up stuff (like head bolts)?
Plus since I really hate to redo stuff, and I'd be pretty well into the top end of that beast anyway ... should I go ahead and do the bullet-proofing (EGR delete, etc.)? Or should I tear it apart and look for the telltale signs of impending disaster and evaluate then?
dhbpac is offline
post #2 of 5 Old 07-04-2013, 12:53 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
If your money and time allows for you to bullet proof the motor, then why not? You can upgrade the turbo with stock head bolts. Take a look at MTW stage 1 or hybrid since you tow your tuck will love these turbos. I'd also free up your exhaust for lower EGTs and a little more power. Make sure you update all the little things these motors are know to be trouble makers…
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 5 Old 07-04-2013, 04:09 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Check out this link
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #4 of 5 Old 07-04-2013, 01:46 PM Thread Starter
Got that one tagged as a favorite. Also found several others.
Thinking about starting with Sinister coolant filter & EGR upgrade, K&N Cold Air Intake, and CFM LargeMouth intake.
When I get the turbo, etc., apart I'll make a decision about other stuff. I really like the Sinister setup, and would likely go with their closer-to-stock turbo & oil cooler mods.
The only question left is which tuner ...
dhbpac is offline
post #5 of 5 Old 07-05-2013, 04:17 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Any of the SCT's are great options and any of the tune writers that are frequently mentioned here on the org are all great options. e.g. Tony Wildman, Bill at PHP, Vivian @ Quicktricks, Eric @ innovative diesel, Matt @ gearhead...
Shawn
Qholic is offline
