2005 F250 left turn signal and brake light now working. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-03-2013, 06:03 PM Thread Starter
Please don't yell at me. I promise I searched first for my answer but couldn't find a match. Just bought a 2005 F250 and the guy said the turn signal stopped working on the way home the day before. I drove the truck when it was working so I believe him. Thought it was just a bulb because it is blinking fast. Bulb is good and I even swapped the socket for the right on. Still nothing. Outside of a broken wire, anyone had this happen? I called myself checking the fuses and they all look good. Haven't been able to check much else due to rain so I thought I would check here. Thanks.
seeemmiss is offline
post #2 of 5 Old 07-03-2013, 11:58 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Originally Posted by seeemmiss View Post
Please don't yell at me.:
lol, sounds like a wire shorting out. Are the trailer lights doing the same thing on that side?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 5 Old 07-05-2013, 05:47 AM Thread Starter
I haven't checked a trailer yet but i will when I get home. Thanks
post #4 of 5 Old 11-18-2013, 01:23 PM
jtaylor75's Avatar
mine is doing the exact same thing. Have you found out what it is yet?
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #5 of 5 Old 11-19-2013, 01:19 PM Thread Starter
Yep. It was a wife pulled out of the factory plug. The entire pin was pled free from the plug some how. On e I traced it to the plug, it was easy. Good luck and hope this helps.
2005 F250 CCSB 4x4
Yep. It has studs.
