Boost Fluctuation - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-01-2013, 01:16 PM Thread Starter
adam214's Avatar
Quoted: 6 Post(s)
Boost Fluctuation
Hi Guys, I recently bought a 2004 F250 with the 6.0 PSD. Ever since i had it, the boost would fluctuate slightly under load or cruising down the freeway. I recently welded my EGR cooler shut and cleaned my oil cooler. I removed the turbo and cleaned it all up. I put everything back together and its worse! I had an exhaust leak at the clamp to the EGR cooler. Fixed that but boost still fluctuats. You can hear the turbo whistle fluctuate up and down through out the power band. Installed a boost gauge and you can see the needle move up and down, up and down. Replaced EBP sensor, cleaned tube, cleaned MAP sensor and nipple and hose. Cleaned IAT nipples. Removed IPR valve and cleaned. Ran scanner and everything seems to be withing spec. Only fluctuation i see in anything is the EBP sensor is showing the fluctuation. Removed turbo 6 times to verify everything was OK. Install custom tunes to see if that would help, Nope. Any advice would be appreciated. Thanks!
adam214 is offline
post #2 of 5 Old 07-01-2013, 03:07 PM Thread Starter
adam214's Avatar
Quoted: 6 Post(s)
Anyone? I am about ready to blow this thing up.
adam214 is offline
post #3 of 5 Old 07-04-2013, 12:01 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Is it possibly the turbo surging? How is the play on the turbos shaft?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 5 Old 07-04-2013, 01:26 PM Thread Starter
adam214's Avatar
Quoted: 6 Post(s)
It could be. I have pulled the turbo out 7 times and te shaft seems to have no play. It is pretty tight. the only noticable thing with the turbo is it spins better one way, than the other? I have a boost gauge tapped into intake elbow and boost pressure is fluctuating.
adam214 is offline
post #5 of 5 Old 04-19-2016, 02:27 PM Thread Starter
adam214's Avatar
Quoted: 6 Post(s)
Im sure no one cares but it turned ot being the turbo. my wife called me and said the truck was smoking and low power. I towed the truck home and removed the turbo. the VGT actuator came apart. put a new actuator in it, same issue. long story short, the linkage horn in the exhuast side of the turbo that moves the unisom ring would stick. Threw a powermax turbo on it and problem solved. I hope this helps anybody else.
adam214 is offline
