Fuel gauge problems??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-30-2013, 06:08 PM Thread Starter
JOEDOG223's Avatar
I filled my truck up this morning and it was only reading half a tank. It's had issues other times too. The other day I was driving and it randomly dropped to below empty and said low fuel. I stopped and turned the key on and off a few times and It came back up to 3/8 of a tank when it was at 4/8 before it happened.
Today after driving for about ten minutes it went up to 3/4 and then full.
I'm just wondering what the problem may be and if any one else has had issues with it.
The truck is an 05
Thanks
JOEDOG223 is offline
post #2 of 6 Old 07-04-2013, 12:11 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I've had this happen to me before also… did you turn the key on while filling up? Next time do NOT turn key on and I bet it doesn't happen again.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 6 Old 07-04-2013, 07:12 AM
I've had this happen before as well. My shop said to run Chevron Techron in the tank. According to them, there was some TSB on sticking fuel sensors that the Techron stuff clears up. It worked for me.
kts1964 is offline
post #4 of 6 Old 07-04-2013, 08:10 AM
Chapter Director
I fill up with my truck running most of the time and don't have this issue.
2015 Tuxedo Black F350 6.7 CCSB 4WD PLATINUM
2006 White F350 6.0 CCLB 2WD
dowmace is offline
post #5 of 6 Old 07-09-2013, 10:57 AM Thread Starter
JOEDOG223's Avatar
Okay. Thanks I may try that. I do think I turned my key on when I was fillin up. But they still doesn't explain why it does it when driving.
post #6 of 6 Old 07-09-2013, 01:05 PM
Quoted: 8 Post(s)
The ECM uses different methods of verifying the fuel level in the tank to help with inaccurate readings(fuel sloshing in the tank) I actually think there is four different methods.
When the key is off and then turned on it only take a few seconds to move the gauge because in the 1-2 seconds after the key is turned on its reading the sending unit and if the ohms don't change it instantly gives your gauge a reading.
Now, key off (while fueling) and then the key is turned on and in that 1-2 seconds (as the ECM is reading the sending unit) the ohms are changing and the computer thinks the fuel is sloshing around and so it defaults into a mode were it changes the gauge takes up to 60 seconds to go from empty to full(anti-slosh mode). This mode always being used while driving to prevent the gauge from bouncing all over the place like all the old cars and trucks do.
The mode I believe you experienced happens after the ECM defaults into anti-slosh mode and fuel is rising rapidly. I believe its called recovery mode. Its where the ECM is in Anti-slosh mode and (for example) the gauge is reading 1/2 tank and the next series of readings keeping showing the gauge at 3/4 and rising. (gauge reading is below actual sending unit reading) This makes the computer go into a so-called limp mode and cause the ECM to take up to 20 minutes from empty to full. I believe this mode is used to prevent the gauge needle from jumping up in increments every minute or so.
The times for each mode might be off slightly...
As for dowmace, I believe his gauge read normally because he doesn't shut the truck off causing the ECM to take up to 60 seconds to reach full but filling the tank takes longer so he never see the problem. This problem only occurs once the truck is shut off and them turned back on while fueling... Hope that makes sense
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
