EOT sensor? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-30-2013, 10:19 AM Thread Starter
King Rancher_27's Avatar
EOT sensor?
So I noticed the other day after the truck was at operating temp I stopped at a friends house (leaving the truck running) After a few minutes we left to go to town and I noticed my eot was @ 20-30 degrees cooler than my ect (190-195). Before I stopped at his house my delta was normal @ 5-7 degrees apart. So we got into town ate lunch did some more running around and it was reading fine again. Now on my way home this morning from work (about a 30 min drive) temps were fine till about 5 mins from my house and I watched my temps go from 190-ect, 198-eot to 190-ect, 174-eot and stayed there till I got home. I'm just wondering if my EOT sensor is going out? Any help would be appreciated!
Sent from AutoGuide.com App
-Casey
2012 F250 FX4 stock with 3.55 gears
2006 F250 King Ranch FX4--SOLD
ARP Studs-OEM gaskets(this time
SCT with IDP tunes,Gearhead tunes & TSD TUNES
EDGE CTS insight
5" TB with 6" Tip no kitty or muff
Sinister Delete Kit
Upgraded oil cooler
leveled w/ 295/70/18 Nitto Trail terrian
6.4 banjo bolts
Blue Spring Upgrade
KC Stage 3 68mm Turbo
Ported Intake
S&B CAI
190/75 Renagade injectors
STC fitting
King Rancher_27 is offline
post #2 of 3 Old 06-30-2013, 04:16 PM
gotta_gofast's Avatar
Quoted: 60 Post(s)
Swap your EOT sensor with your ECT sensor and see if the readings follow the sensor or stay with the oil temp. If your EOT stays constant but your ECT fluctuates, purchase a new sensor. If the EOT still fluctuates, I would check the wiring harness or harness connector for faults.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #3 of 3 Old 06-30-2013, 05:42 PM Thread Starter
Thanks! I was gonna try that when i get off from working nights. Its doing it more often now and i noticed on my way to work today it was fine then i let off the skiny pedel and my EOT went from 195 to 170 throtle back up and it came back up lol. IDK ill see what happens when I swap them
-Casey
EDGE CTS insight
Sinister Delete Kit
Upgraded oil cooler
6.4 banjo bolts
Blue Spring Upgrade
Ported Intake
S&B CAI
STC fitting
