A/C issues - Ford Powerstroke Diesel Forum
post #1 of 19 Old 06-30-2013, 07:04 AM Thread Starter
A/C issues
The A/C quit working on my 2006 the other day... driving down the highway for ~15mi, the air was working fine, and then I noticed it was blowing hot. A few minutes later, it went back to cold, and then a few more minutes, back to hot. It did this three times in the 15 miles. When I drove the truck the next day, the A/C was not working at all. I figured that it may be low on freon because the compressor is not kicking on, so I bought a self charging kit and tried it out. When I hook it up, the needle on the gauge is completely pegged out to max, and I can't get the system to take any of freon.
I don't think the gauge works right unless the compressor is turning (is this right?), so I'm not worried about the reading (yet anyway). I tried the can on my wife's 4Runner (A/C works), and it seems to work fine. The gauge reads well and the can transfers freon (it gets cold in my hand). Any idea why I can't put any in the truck? What else should I look at?
MTW Stage 1
4" MBRP Exhaust
SCT Custom Tunes
Stock TTY Head Bolts
TexasA&M is offline
post #2 of 19 Old 06-30-2013, 08:24 AM
sprksonu's Avatar
the needle is pegged because the clutch is not engaged, sounds like you might have a pressure switch issue
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #3 of 19 Old 07-01-2013, 03:28 AM Thread Starter
I think that the connector from the freon isn't making good connection. When I hook it to another car and pull the trigger, you can hear and feel the gas running out of the can. When I hook it to the truck, nothing happens. Same thing when I hook up a set of gauges; they don't change at all when I open the valves.
Any thoughts?
MTW Stage 1
4" MBRP Exhaust
SCT Custom Tunes
TexasA&M is offline
post #4 of 19 Old 07-01-2013, 11:15 AM
astroinhouston's Avatar
Your compressor clutch has to be turning for it to draw from the can. Guages wont tell you a thing if the clutch isnt engaged. If you are low on freon the clutch wont kick on as precaution and you need to jump the relay with a paperclip. If that doesnt work you need to test your pressure switch as a previous poster suggested.
SOLD (and regretting it everyday since)
2006 King Ranch Long Box
DieselSite Coolant Filter
SCT w/custom tunes
4" Magnaflow Straight Pipe
Edge CTS w/EGT
Bilstein 5100's
astroinhouston is offline
post #5 of 19 Old 07-01-2013, 01:33 PM Thread Starter
Then why can I hear and feel freon leaving the can when I hook it to my wife's car with the engine off? I've charged systems before starting at empty and the compressor doesn't come on until the pressure is high enough. There should be enough pressure in the can to put at least some in the system.
MTW Stage 1
4" MBRP Exhaust
SCT Custom Tunes
TexasA&M is offline
post #6 of 19 Old 07-01-2013, 03:00 PM
Powerstroke Techie
Quoted: 15 Post(s)
Garage
Feedback Score: 4 reviews
If the pressure in the can is higher than the pressure in the vehicle the can will empty into the veh. That's the only way it works
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #7 of 19 Old 07-01-2013, 06:08 PM
If you are looking to push freon in you can always set the can in a bowl of hot water. Not boiling just as hot as it will get from the tap. It will take some time too without the clutch engaged. With that said, i would be very cautious of trying to add freon without being able check the pressure. Have you tried jumping the clutch relay?
SCT w/custom tunes
Edge CTS w/EGT
Bilstein 5100's
post #8 of 19 Old 07-03-2013, 05:48 PM
southend's Avatar
Unfortunately, these systems are prone to the dessicant bag busting. That clogs the orfice, then when the compressor kicks on the pressure shoots up and the high pressure switch will shut it down. Thats my guess.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #9 of 19 Old 07-03-2013, 07:38 PM
Send a message via Skype™ to bwmtnbiker
As stated before, if the gauge is pegging out than the compressor is not running. You need to try jumping the relay to make it come on for just a short period so it will draw in the freon.
I just got done replacing my whole system, evaporator, drier and condenser. The compressor was new from the last time it blew up and quit. A/C systems are very picky, learned from experience working at a pepboys shop.
-Brian
2003 F-250 6.0L - Lariat King Ranch
-300k+ miles and still strong
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-SCT X3 (Tuned by Vivian
-4" Turbo Back Silverline Exhaust, 5"tip
-Blue Spring Mod
-Sinister Coolant Filter
-Oil Cooler
-Sinister EGR Delete
-OEM Cab Lights
Wants/Soon
-ARP Studs
-MTW Stage 1 or Hybrid
-6.4 Banjo Bolts?
bwmtnbiker is offline
post #10 of 19 Old 07-03-2013, 07:50 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
BINGO he hit the nail on the head!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
