Intermitten hard/no start - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-28-2013, 03:14 PM Thread Starter
msmith's Avatar
Quoted: 7 Post(s)
I have been having a hard/no start problem for a while. At first I was thinking dummy plugs, or some hpo problem, because it has never done it on a cold engine, only hot and after it has been shut down for 10 - 60 minutes, but it is intermittent. So now I let the Edge cts boot up before cranking each time I start it. Had it happen twice since. FICM v = 49 - 49.5v, ICP = 675+. Of course after cranking I get the P2614 & P2617 codes. I clear them each time.
Any ideas? Oh, and the fuel economy is in the toilet now too. The liar on the dash is saying about 14.8 @ 50mph flat, level ground. In the past it would have been 19 - 20. Don't know. Just thought the two could be related.
Thanks in advance,
Mike aka Lineman
AUT VINCERI AUT MORI
as for me and my house, we will serve the LORD. Joshua 24:15 KJV
2015 F350 CCSB FX4
2007 Dark Stone F-250 CCSB Lariat 4x4, SOLD
20" Mastercraft Courser AXTs
CCV reroute
Edge CTS
PMM coolant filter
Diamond Eye 4" turbo back
SCT X3 w/Looney tune
Vision Diesel Stage 1 turbo
msmith is offline
post #2 of 8 Old 06-28-2013, 04:21 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
Thanks in advance,
It could be a variety of problems going on. Icp seems good. Whats icp vs desired while running. Wiggle your wiring harness around while someone starts it- ficm and main engine harness see if it clears up or starts up right away. Whats your fuel pressure like?
Pretty much need to go through the whole "nostart sticky" and see what doesnt check out cause those codes are most likely just from a long crank time.
Keep us posted
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #3 of 8 Old 06-28-2013, 05:46 PM Thread Starter
msmith's Avatar
Quoted: 7 Post(s)
Thanks. Been perusing the "no start" sticky.
A side note. When I get the hard start, right after it starts it has no throttle response whatsoever for a few seconds. It just idles and barely does that, then while holding the accelerator down, after a few seconds it suddenly takes off.
I'm a bit ticked. Onl 97k on it and I'm already starting to have issues.
Mike aka Lineman
2015 F350 CCSB FX4
CCV reroute
Edge CTS
PMM coolant filter
msmith is offline
post #4 of 8 Old 06-28-2013, 05:57 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
No problem, and yea i can share your frustration there... Im not familiar with all the parameters that the cts will pickup on... Can it see ckp and cmp Sync?
When starting... What is ipr duty cycle, icp desired and icp actual? You might want to pull up RPM and monitor that as well. If it says zero or has out of the ordinary numbers then it could be no SYnc or a bad sensor.
One more thing, check your actual battery voltage with a multimeter while cranking... Your ficm voltage can be perfect but your battery voltage can be lower than 11v which will cause a no start as well as RPMs to be under a certain amount which will not allow the pcm to start. Pull as many values as you can. Good luck
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #5 of 8 Old 06-30-2013, 06:16 PM Thread Starter
msmith's Avatar
Quoted: 7 Post(s)
Aarrrgh! done it again this eve at Church. Rolls over fine, fires and rolls on it's own for a few seconds then quits. Done this several times and a couple of times it ran long enough that you thought it was going to take off then....it quit. Finally, after being ribbed about buying a dodge or a chevy, or borrowing a dodge to ride home in, it took off. Ran fine all the way home, I shut it off then it restarted just fine. Go figure.
Mike aka Lineman
2015 F350 CCSB FX4
CCV reroute
Edge CTS
PMM coolant filter
msmith is offline
post #6 of 8 Old 06-30-2013, 06:22 PM Thread Starter
msmith's Avatar
Quoted: 7 Post(s)
I just tried it again. Stumbled a bit but started. I'm thinking it's gotta be a fuel problem. I'm going to try changing the filters first, but the more I think about it, the electric pump sounds a bit different. I may try that next after making sure the lines are clear.
Mike aka Lineman
2015 F350 CCSB FX4
CCV reroute
Edge CTS
PMM coolant filter
msmith is offline
post #7 of 8 Old 07-01-2013, 01:24 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
Make sure filters are all motorcraft and try to check fuel pressure. Make sure your caps arent broken also. Might have air getting in the lines as well. Any problems with injectors, Hfcm, fuel pump etc?
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #8 of 8 Old 07-01-2013, 03:33 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
Based on your description, I suspect a faulty FICM, a bad harness or plug corrosion, or even an IPR issue. I would check the the FICM, and IPR/ICP relationship as you try to start or move when there is a problem. Of course, the codes you have indicate a CMP and a CKP problem. To have both OPEN is a bit unusual, but being intermittent, it is probably a wire harness issue. You need to eliminate the good items and focus on what is consistently bad. Not so easy on how it seems to present itself.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
