code P0275 - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-27-2013, 05:34 PM Thread Starter
code P0275
Hey guys I Have a 05 250 throwing a P0275 code that started with a bad injector that the tip split and started dumping fuel into the cylinder. Replace the injector and i'm still getting the same code. checked ficm voltage and I have 48.5 with the truck running. done a power balance test and #5 cylinder is dead. I can disable the injector and there is no change. done a buzz test on injectors and they all pass. Any Help or information would be greatful. Thanks
kickingk5 is offline
