Check my troubleshooting so far on my No Start issue please - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-27-2013, 08:18 AM Thread Starter
The basics - 2005 totally stock, 70 k miles. Just put in a new EGR valve about 500 miles ago and rebuilt FICM about 2000 miles ago.
Truck started normally, put her in gear and backed down the driveway about 3 feet, truck stalled and will not restart.
Batteries are fine. Oil level is fine, fuel level is fine and fresh fuel filters ~ 500 miles.
All fuses are fine, fuel pump cutoff checked.
key on values with SG II -
IPR 1.7
FMP v 49
ICP 171
Cranking values
IPR 5.31
FMPv 49.5
ICP 401 initially, goes to 1001 after 5 seconds or so.
Note, the in-cab oil pressure needle did not move even after a 15 second crank.
I forgot to get RPM's but she was spinning fine, over 1000 for sure.
My next step is checking FICM Sync and CKP CMP sync.
Anything jump out at you guys so far?
Any suggestions?
2005 SRW f350 Lariat CC 8ft bed, black!
Matches my 03 black turbocharged Marauder!
jupiter is offline
post #2 of 4 Old 06-28-2013, 04:42 AM Thread Starter
bump for help!!
jupiter is offline
post #3 of 4 Old 06-28-2013, 05:47 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
IPR 1.7
FMP v 49
ICP 171
Cranking values
IPR 5.31
FMPv 49.5
Any suggestions?
Make sure it is getting fuel to the upper bowl. If you can check fuel presure with a gauge that would be good if not your gonna need to atleast make sure its getting fuel to the bowl. Any codes? Also your either not gwtting low pressure oil or the oil pressure sensor is bad.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #4 of 4 Old 06-29-2013, 02:10 PM Thread Starter
Nope no codes. Hellish storms today so not much getting done!
jupiter is offline
