Air Leak from Turbo - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-25-2013, 09:56 PM Thread Starter
Air Leak from Turbo
I have a 2006 F350 with 6.0 and there is a air leak coming from the turbo you can feel it coming from the exust side of the housing right on top. Does this mean my turbo needs to be replaced or is there a gasket inside I can replace.
Hutch310 is offline
post #2 of 3 Old 06-29-2013, 03:18 AM
mustangmike6996's Avatar
are the bellows on the pipes leading up the turbo cracked?
mustangmike6996 is offline
post #3 of 3 Old 07-08-2013, 10:34 PM Thread Starter
Found out the Y pipe was loose on the back side had to reloosen everything including the turbo to get it to reseal. Thanks for your reply
Hutch310 is offline
