Wheel bearing - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-25-2013, 06:43 PM Thread Starter
Wheel bearing
I have a 2005 f 350, long bed, xl. I can hear noise and feel something in my left front end when traveling over 30 and slightly turning left. I found the whole hub w/ bearing assembly on ebay for 140 bucks with abs, I was wondering what special tools i would need to do replace hub? Just bought the truck and havent done this before.
Thanks!
grizzly90 is offline
post #2 of 6 Old 07-01-2013, 10:23 AM
its not bad, i just did both of mine a couple of months ago. I didnt need any special tools for the hub, but i did replace my ball joints while i was at it and those needed a ball joint press
power43 is offline
post #3 of 6 Old 07-04-2013, 12:05 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Do yourself a favor and buy OEM or Timkens… you WILL be redoing the bearing very shortly if you don't purchase high quality wheel bearings.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 6 Old 07-04-2013, 01:05 AM
Quoted: 904 Post(s)
Feedback Score: 3 reviews
What he said. BTW, OEM's are make by timken.
Corey@CNCFAB is offline
post #5 of 6 Old 07-04-2013, 06:35 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 6 Old 07-05-2013, 05:08 AM
dxusmc's Avatar
yea, please don't make the same mistake I did and go with one of the cheaper Ebay items. I think it lasted 3-4 months before that entire wheel seized up on my way home from work. Still found a good deal on Timkens (bought a pair just in case) for like $350 on ebay. Haven't had a problem since..so it looks like I'll have this spare for awhile. Only "problem" I had, was the studs came in a different thread, so I had to swap out from my old hub. Thought that was strange, but haven't had problems so I guess it was just a fluke.
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
