park switch - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-25-2013, 11:15 AM Thread Starter
park switch
hey i have this problem where i can start my 03 f250 and it will run and all my lights and accessorries work but when i push on the brake it will not let me get out of park and i have to sit there for a while until it finally pops in after playing with it.
i found this brake light switch it says it controls lights and the cruise control off switch but does it control my parking paw?
Ford F250 Truck Brake Light Switch Replacement | Ford F250 Truck Stop Light Switch | Ford F250 Truck Stop Lamp / Brake Lamp Switches At 1A Auto
could it be something else?
ddlwfo94 is offline
post #2 of 4 Old 06-25-2013, 02:32 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Most likely that switch is your problem, it sends a signal to the brake lights and also sends a signal to your interlock solenoid in the steering column to release the shifter from park.
In an emergency if your truck won't shift out of park, shut off the engine, then turn your key to the run position, hold the brake and shift the truck into neutral, then start the truck and shift to drive or reverse.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 4 Old 06-29-2013, 03:10 AM
mustangmike6996's Avatar
Make sure your brake lights are working when you depress the pedal, i know a lot of cars use that signal to control the shift interlock
mustangmike6996 is offline
post #4 of 4 Old 06-29-2013, 06:43 AM Thread Starter
It was the park switch thanks for the help
ddlwfo94 is offline
