Edge cts warning - Ford Powerstroke Diesel Forum
post #1 of 24 Old 06-22-2013, 07:03 PM Thread Starter
SnoracerX's Avatar
Edge cts warning
I keep getting this warning since I installed my cts took a video everything looks good otherwise I just don't know what the warning is for the pid is injector power here is a video
truck also surges on its own the throttle was applied during the video to show the parameter movement
http://youtu.be/SmhnJwj4JeA
SnoracerX is offline
post #2 of 24 Old 06-22-2013, 07:06 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Lots of threads about his already, just turn off the alarm for his PID and wait for an update to fix this issue.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 24 Old 06-22-2013, 07:29 PM Thread Starter
SnoracerX's Avatar
Ok I was wondering what it is monitoring I have a wierd surge issue that I thought might be related
post #4 of 24 Old 06-22-2013, 09:02 PM
Quoted: 8 Post(s)
Did your problem happen after updating your CTS?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 24 Old 06-23-2013, 04:47 AM Thread Starter
SnoracerX's Avatar
No I just hooked up the cts for the first time yesterday wasn't an update available
post #6 of 24 Old 06-23-2013, 12:28 PM
Quoted: 8 Post(s)
The surging you are referring to... Is it a turbo surge? Or possibly a fueling issue? Are you running any performance tunes in the truck? You need to monitor the icp volts(or pressure), ipr %, FICM volts, VGT cycle % and APP(throttle position) along with the ECT and EOT. Checking all of these numbers can help you determine what is the cause of your problem. Update your sig so other members can help give you an informed answer.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 24 Old 06-23-2013, 02:11 PM Thread Starter
SnoracerX's Avatar
Ill post here what the truck has now and when I get near a computer
04 excursion egr delete blue fuel spring
Studded turbo just cleaned 7 k ago
Coolant filter cat elc
New icp sensor 84 k on the truck
Using edge cts for monitoring
The surge is like someone else is pressing the throttle some times it will almost stall then catch itself by heavy throttle if your not ready for if it will push through the brakes
post #8 of 24 Old 06-23-2013, 02:48 PM
Quoted: 8 Post(s)
So it does this at idle with your foot on the brakes?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 24 Old 06-23-2013, 03:17 PM Thread Starter
SnoracerX's Avatar
Yes and it does it while going down the road the tune has no effect on it it is stick tight now and still acting up
post #10 of 24 Old 06-23-2013, 03:31 PM
Quoted: 8 Post(s)
Look at your APP numbers at idle, in drive with your foot on the brake. If the numbers are changing then its your accelerator pedal. Had this happen in my 99 f350, not hard to change out. Can't remember the price though.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
