Poor mileage since injectors - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-22-2013, 04:12 AM Thread Starter
powerstrokecrzy's Avatar
Quoted: 227 Post(s)
Alright need since help here guys. Ever since I put injectors in (warren 175/stock). My mileage has been bad, around 12 driving conservatively. I would think it would be better. I had to put a new ebp valve on cause I messed it up installing the injectors. No codes, all readings are good (ficm, vgt, ipr, ipc). I just don't know where to look or am I expecting to much?
Edit: running looney wild track, should I talk to vivian bout this? Got wildman tunes on order to try them out.
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #2 of 6 Old 06-22-2013, 05:22 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
i would think it maybe the tuning or your right foot, lol. but try the TW tunes first and then make sure youre not in the throttle alot more than normal. i know I was when i put my sticks in.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 6 Old 06-22-2013, 05:52 AM
04cr450's Avatar
My truck had horrible fuel mileage when I installed my 175/75's... After a couple weeks of driving- the truck increased fuel mileage back up to where it was before(16-18) in city/mix of highway. I did not change my driving characteristics- I believe it wad the truck getting used to all the new items/tunes.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #4 of 6 Old 06-22-2013, 07:02 PM Thread Starter
Quoted: 227 Post(s)
I've had them in for bout 2 months now. I've tried taking it easy for an entire tank and still the same.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #5 of 6 Old 06-23-2013, 12:26 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
It's not the injectors. Most likely a tuning issue.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #6 of 6 Old 06-23-2013, 06:08 AM Thread Starter
Quoted: 227 Post(s)
Thats what I'm thinking and hoping. Hopefully the tw tunes will help.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
