Help! Dropped 8mm socket and 3 inch extension where HPOP sits - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-19-2013, 04:43 PM Thread Starter
I have a pretty serious situation, I was removing my HPOP and dropped a socket and extension down into the spot where the pump sits. It fell down between the block and the gear on the end of the camshaft that drives the pump. any suggestions on what I should do? Tried using phone camera to look down in to see if it was laying where I could see it and possibly retrieve it... but cannot see anything. Did it fall down inside of the motor? Any suggestions would be a huge help! Thanks
bpowerstrokin is offline
post #2 of 10 Old 06-19-2013, 05:01 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Have you tried "fishin" for it with one of those magnet bolt picker uppers?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 10 Old 06-19-2013, 05:09 PM Thread Starter
Yes I fished for about an hour with a magnet and grabber... I guess the big question is how far could it fall?
post #4 of 10 Old 06-19-2013, 05:11 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Send Tuscany a pm he'd be able to tell ya
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 10 Old 06-19-2013, 05:14 PM Thread Starter
Ok will do! Thanks for the help! Greatly appreciated
post #6 of 10 Old 06-19-2013, 06:00 PM
brscott38's Avatar
Had this problem once before. Drain the oil and then tap on the oil pan with a rubber mallet with any luck it fell all the way down. You should hear it rattle when you tap the pan. If u hear it rattle start fishing with a coat hanger. I dropped only a 8mm socket no extension and this worked for me. I fished forever with no luck then a buddy showed up and saw me cussing so he tried and got it within three minutes of trying. So good luck it can be done I have seen it. Oh ya 8mm is a very tight fit through the drain hole.
brscott38 is offline
post #7 of 10 Old 06-19-2013, 06:04 PM
ZMANN's Avatar
Quoted: 1568 Post(s)
was that on a 6.0 oilpan ?
We Miss you Ronnie
ZMANN is online now
post #8 of 10 Old 06-19-2013, 06:10 PM Thread Starter
Thanks for the tips. I'm going to use an inspection camera to see if I can see anything tomorrow. Hopefully I can retrieve it.
post #9 of 10 Old 06-19-2013, 06:10 PM
brscott38's Avatar
Yup
post #10 of 10 Old 06-23-2013, 12:14 PM Thread Starter
I successfully fished it out yesterday with an inspection camera with a magnet attached to the end of it. it was about 18 inches down in. Thanks for all of the help.
Tags
6.0 motor problems , dropped tools
