Starter Issue - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-17-2013, 05:31 PM Thread Starter
Starter Issue
So i put a new flywheel, starter, and hpop o-ring kit in my 03 F-250 6.0 4x4. After i got it put together it wouldnt start. It would just click. Well i re aligned the tranny to see if that would work and only got a click. So i took a screwdriver and crossed the two post on the starter and bam sh roared to life. It ran for a couple of days and then it went back to clicking. So i ohm'd the small wire out and got .2. then i cleaned out some of the relays in the engine bay. There was some mud from a couple of years ago in there. Looked at some of the fuses but the haynes manual i have doesnt show the 2003 6.0 electric diagram so i didnt have anything to go on. so put everything back together and it started right up. It got me to work and back on friday and monday for dinner. But today i went to go back to work and got the dreadful click again, threw a screwdriver back up there and started right up. I got back to work shut the truck off and restarted it with the key just fine but i know i will go out there later tonight and i will get the click noise. Im not sure what it could be. Any help would be awesome.
Thanks
Steve
coolsun is offline
post #2 of 13 Old 06-17-2013, 05:40 PM
ZMANN's Avatar
Quoted: 1344 Post(s)
you say " new" starter?
We Miss you Ronnie
ZMANN is online now
post #3 of 13 Old 06-17-2013, 05:56 PM
ZMANN's Avatar
We Miss you Ronnie
ZMANN is online now
post #4 of 13 Old 06-17-2013, 06:02 PM Thread Starter
Well a new reman starter.
coolsun is offline
post #5 of 13 Old 06-17-2013, 06:04 PM
ZMANN's Avatar
no issue before?
I am thinking a solenoid issue
it sounds like it is pulling in but not connecting the 2 large post
We Miss you Ronnie
ZMANN is online now
post #6 of 13 Old 06-17-2013, 06:08 PM Thread Starter
the only issues i had before was a no hot start. which is why i put in the new o-ring kit and the starter would spin but wouldnt engage the flywheel. Which is why i replaced the flywheel but when we got tranny down the flywheel looked really good but we changed it out anyways since we had done all the work. and thats when we replaced the stater.
coolsun is offline
post #7 of 13 Old 06-17-2013, 06:09 PM Thread Starter
I will take the starter down tomorrow and take it to the shop and have them test it.
coolsun is offline
post #8 of 13 Old 06-17-2013, 06:12 PM Thread Starter
I was pretty heated on the Hpop. I just had this engine built back in 2011. the company put the wrong o-ring in under the hpop.
coolsun is offline
post #9 of 13 Old 06-17-2013, 06:15 PM Thread Starter
Thank you ZMANN for the input i will let you know what happens.
coolsun is offline
post #10 of 13 Old 06-17-2013, 06:50 PM
ZMANN's Avatar
the starter may test good
parts houses typically can't real world test a starter since they can't put a flywheel load on it
so if it spins they call it good
and on the solenoid the ones I have seen use a contact disc and that disc moves every start so it's working on a different area but once you have a bad spot it wont work
so either have em swap the whole thing / or the solenoid
or at least have em test the starter multiple times using the solenoid start post and not just the large starter post
your old starter probably had a bendex issue and it wasn't throwing out the gear into the flywheel
We Miss you Ronnie
ZMANN is online now
