Oops..alternator issue - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-16-2013, 05:23 AM Thread Starter
dxusmc's Avatar
Anyone ever strip out the positive post on the alternator? Also broke about 1/4" off of it. Just wondering if anyone has an experience taking it apart and putting a new one in there.
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #2 of 5 Old 06-16-2013, 05:49 AM
taskforcefreddy's Avatar
Yup! Worse yet, snapped mine right off making it useless. I took it right back to pep boys and they gave me a new one, no questions asked. Is yours new or are you simply re-installing the old one?
taskforcefreddy is offline
post #3 of 5 Old 06-16-2013, 05:51 AM Thread Starter
dxusmc's Avatar
going to be re-installing the old one unfortunately. Worked fine, just broke and stripped during removal. Looked like the nut caused it. I tried reversing the 1 nuts so I could still get a bite, just wouldn't thread.
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #4 of 5 Old 06-16-2013, 06:56 AM
That sucks man. Not sure if you can simply weld it on there or not... maybe a ton of solder or something? Would probably vibrate off eventually.
post #5 of 5 Old 06-16-2013, 07:13 AM
Term3's Avatar
Quoted: 2 Post(s)
Welding would destroy the diodes and solder probably wouldn't hold. At work we have connectors that join two threaded rods together so if you can find one of those at a hardware store you could try re-threading it to the fine thread of that snapped off bolt
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
