alternator issues. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-14-2013, 04:14 PM Thread Starter
alternator issues.
Hello. 06 f350 with dual alternators. Truck hard to start sometimes doesn't start, unless I jump it. Tested batteries, they were good. Tested alternators they charge good. Volts after starting are 14.1. Shut key off and tested volts on alternators and they continue to pull 2 volts even with key off. Told I need to replace alternators, they are remans with 150,000 miles. Is it alternators or something else. please help...Thank you!!
dinos is offline
post #2 of 12 Old 06-14-2013, 05:33 PM
Quoted: 822 Post(s)
What is the voltage during cranking? May be too low for ficm to work. Alternators may be charging but not quite to where they should be.
Corey@CNCFAB is offline
post #3 of 12 Old 06-15-2013, 07:04 PM Thread Starter
Voltage during cranking was 11.2. Retested batteries under load and one came up as bad. Replaced both batteries with interstate xtp65 or something like that, supposedly there best and strongest battery. Started fine remainder of the day, well see what happens after sitting all night....
dinos is offline
post #4 of 12 Old 06-15-2013, 07:08 PM
ZMANN's Avatar
Quoted: 1673 Post(s)
Who told you a 2 volt drain was a bad alt LOL
I bet you got it fixed the drain was the bad battery sucking down the good one
We Miss you Ronnie
ZMANN is offline
post #5 of 12 Old 06-15-2013, 07:21 PM Thread Starter
First shop I took it too. Said alternator was pulling 2 volts and draining the battery ??? Hopefully It is fixed. Thanks for the responses !!!
dinos is offline
post #6 of 12 Old 06-15-2013, 07:28 PM
ZMANN's Avatar
Alt pulling volts not running '
after making a good output running
Never heard anyone try that diagnosis before
We Miss you Ronnie
ZMANN is offline
post #7 of 12 Old 06-15-2013, 07:32 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Didn't know anything could pull volts :
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 12 Old 06-15-2013, 07:46 PM
ZMANN's Avatar
technical term may Be Yanking volts ?
We Miss you Ronnie
ZMANN is offline
post #9 of 12 Old 06-15-2013, 07:54 PM
Quoted: 822 Post(s)
Possibly a bad diode that's allowing draw when its not supposed to.
post #10 of 12 Old 06-18-2013, 08:29 PM
mustangmike6996's Avatar
maybe he meant amps??? who knows lol
mustangmike6996 is offline
