A/C making noise... - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-14-2013, 12:58 AM Thread Starter
Koda22's Avatar
Quoted: 5 Post(s)
A/C making noise...
Ok guys my a/c is making some funny noises....if I turn it to the highest setting it makes a loud flapping noise...and only on the highest setting...it's making the noise by the passenger footwell...I'm pretty sure I've gotten something in there but not sure how to chek it, or open it up...any help or tips would be great...
Thanks
Cody
Koda22 is offline
post #2 of 10 Old 06-18-2013, 08:26 PM Thread Starter
Koda22's Avatar
Quoted: 5 Post(s)
No body has any help huh?
Koda22 is offline
post #3 of 10 Old 12-14-2013, 06:34 PM Thread Starter
Koda22's Avatar
Quoted: 5 Post(s)
Ok guys no help yet, but got bigger problems...a/c completely quit on me today....if I turn it on it makes a clunker noise kinda behind the glove box, but get no air from any where....sounds like it's trying to work maybe, but something it broke....someone please give me an idea of wats wrong...I'm lost here
Koda22 is offline
post #4 of 10 Old 12-14-2013, 06:47 PM
huck2080's Avatar
sounds like the blower motor thats what mine sounded like when it went out .. does it blow any heat or a/c ?
huck2080 is offline
post #5 of 10 Old 12-14-2013, 07:24 PM Thread Starter
Koda22's Avatar
Quoted: 5 Post(s)
No doesn't blow anything at all now....just makes the noise....did you replace this your self? Was it hard to do? If not how much did it cost to have done?
Koda22 is offline
post #6 of 10 Old 12-16-2013, 05:26 AM
huck2080's Avatar
was pretty easy i think a1 auto or someone has a video on you tube .. if i recall it was 50.00 buck from oreilys . took me longer to ride to the store to get it then to change it . you could pull yours out 1st to check it out . its only 5 bolts in all
huck2080 is offline
post #7 of 10 Old 12-16-2013, 06:23 AM
Agree pull the blower and check for damages and debri. Also many have a little metal clip on the wheel edge this acts as a balance weight. Check if missing can make the squirrel cage wobble makes a heck of a racket.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #8 of 10 Old 12-16-2013, 06:25 AM
Heavy_GD's Avatar
Quoted: 1338 Post(s)
Feedback Score: 3 reviews
The good news is you just saved yourself some diag time, the down side is you really need to pull it apart to asses what needs to be replaced.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #9 of 10 Old 12-16-2013, 06:40 AM Thread Starter
Koda22's Avatar
Quoted: 5 Post(s)
Well I got it fixed....not to sure wat all was wrong...Took the squirrel cage out and seemed to be lose and not balanced...tighten the end, and it seemed to fix it...put it back together, and turned on the a/c and it wouldn't blow hard enough to get anything to come out...thinking the motor was going bad as well...so a trip to autozone, and 90 dollars later everything it working good...
Koda22 is offline
post #10 of 10 Old 12-16-2013, 09:35 AM
huck2080's Avatar
Sweet
huck2080 is offline
