Ficum Test long start warm - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-13-2013, 04:45 AM Thread Starter
Hi,
I have a 2004 SD and 221000k.
I put a new cover and pump and new STC. It it is studded and has a EGR delete.
I have warm starting
I tested the ficum:
Key ON 48.1v
Running 44.5v to 45v
Could this cause warm starting issues?
Thanks in advance.
robinhood1995 is offline
post #2 of 3 Old 06-13-2013, 05:20 AM
jtaylor75's Avatar
Is your truck a late 04 with the ICP sensor on the valve cover? If so i would try stand pipes and dummy plugs. While your doing those look at the o-rings on top of the injectors to make sure they are not cracked.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #3 of 3 Old 06-13-2013, 05:22 AM
dxusmc's Avatar
Your FICM voltage is starting to drop, but its not quite in the scary zone yet. I'd just start putting some extra coin away though so you can fix it before it gets any lower. Or if you have the coin now, get that one fixed or replaced..sooner the better.
04 MY doesn't have a STC fitting, that's in the 05+ trucks. Might be confusing that with another part. But warm starting issues are usually caused by high pressure oil leaks. Could be dummy plugs, stand pipes, IPR valve might be sticking, or your ICP might be going south on you. To pinpoint, you'd need to get livedata on your ICP and IPR actual vs desired readings. If they test out you'll need to do an air test on your high pressure oil system while commanding the IPR closed and listen for leaks. When you hear it, you pinpointed your problem.
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
