6.0 starting funny, has codes - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-10-2013, 07:12 AM Thread Starter
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
a friend of mine that I work with has a 2006 model 6.0. engine is stock. the problem he's having occurs when he first started up every morning it took so little bit and blows a pretty decent amount of black smoke. upon every other start up after this it starts fine doesn't load or chug and runs perfect. on the initial startup the low ping or choking only occurs for about a minute and then smooths out and goes away. He pulled codes and got cylinders 1 thru 8 all have the code that is something like cylinder is week or something to that effect. He cannot remember the code numbers but all 8 cylinders pulled the same code.he has put something similar to Rev x called arc oil In and change fuel filters and also has changed the oil, and pulled and clean his egr. I thought the problem could be his ficm but wasn't sure and told him I would post this here for you guys to help me diagnose it with him. the truck has just over 100,000 miles on it
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #2 of 15 Old 06-10-2013, 07:26 AM
dxusmc's Avatar
sounds like the FICM. You'll need to get voltage Key On/Engine off and During Running..should always stay around 48. If he doesn't have something to read it, you can do the test with a multimeter. There's a small plate with Torx bolts on top of the FICM, take that off and you'll have access to the pins..I'll have to try finding which pins they are again. I've done it before, but it was awhile ago.
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #3 of 15 Old 06-10-2013, 08:40 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
This sounds exactly whats happening with my truck, I dont have a code reader. So i dont know about the code part... **** im scared now... Subscribed for more info.
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #4 of 15 Old 06-10-2013, 08:52 AM
dxusmc's Avatar
Found the procedure for you guys..relatively easy to do
How to check your FICM for proper voltage output.
(Perform this check when the engine is completely cold.)
Remove the two bolts that hold the coolant reservoir to the cowl and push the reservoir out of the way forward and to your right. You do not need to disconnect any of the hoses.
On top of the FICM is a small cover held on by two #20 Torx screws; remove these two screws and pry the cover off.
On 2003 and early 2004 trucks, you will see 7 screw heads under the cover. On 2004 and later trucks you will see 4 screws.
Take a multi-meter set on DC volts and connect the ground lead to battery negative, and with the key ON measure the voltage at the screw on your right—closest to the driver’s side fender. Do not let the probe short against the case! The voltage should be right at 48 volts. Anything between 47 and 49 is good.
Have an assistant cycle the key and measure the voltage during the initial key-on buzz test. Voltage should not drop below 46 volts.
Next measure the voltage while cranking the engine. If voltage stays at or above 45-46 volts, the FICM is fine. Abnormally low battery voltage can give a false low FICM voltage reading, so make sure your batteries are good.
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #5 of 15 Old 06-10-2013, 01:27 PM
jtaylor75's Avatar
if your getting circuit low codes for cylinder 1-8 and a P0611 code for low FICM power then its FICM going bad.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #6 of 15 Old 06-11-2013, 07:43 AM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Thanks guys. I will be checking voltage on his ficm this weekend. Can auto enginuity monitor ficm volts?
Edit...he came to me this morning abd told me yesterday it took several cranks to get it cranked. But he finally did get it to run. Said cranking was quick and no strain(batteries were replaced last year)
I'm leading towards the ficm at this point
Nick
"The Mistress"
post #7 of 15 Old 06-11-2013, 09:09 AM
dxusmc's Avatar
My understanding..AE can do anything with these trucks. Unfortunately I do not own one, so I don't know how to do it. My guess if its like any other tool..you'd have some sort of option for Livedata..but I might be completely off my rocker here.
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #8 of 15 Old 06-11-2013, 10:00 AM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Well I just bought a scan gauge ll from another member on here...I know I can set the pids to monitor ficm volts. Hoyer It gets here by Saturday. I bought it for my truck but it will come in handy for this job
Nick
"The Mistress"
post #9 of 15 Old 06-19-2013, 05:29 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Forgot to post up what my findings were...ficm voltage was 48.5 key on...cranking it dropped to 24 volts...New ficm is on the way from bulletproof diesel
Nick
"The Mistress"
post #10 of 15 Old 06-19-2013, 05:32 PM
jtaylor75's Avatar
im not going to knock anything from bulletproof diesel because they make BA stuff, but you could have gone with ed at ficmrepair.com for cheaper, you should have also had a mild php tune loaded on it while it was out.
06 CCSB FX4 Lariat
Next:
A fuel system
