Caliper number 3!! - Ford Powerstroke Diesel Forum
post #1 of 47 Old 06-07-2013, 11:51 AM Thread Starter
mrc228's Avatar
Caliper number 3!!
Well, since I'm sitting in a tires plus outside of Greenville GA waiting on my truck to have yet another caliper replaced I thought I'd share my thoughts.....
Halfway between home and North Carolina, on my way to spend some time with family, I get off I-85 to re-route around traffic. After a few lights I begin to smell that all too familiar smell. I think to myself.... No way,not now! My girl wouldn't let me down this far from home... Alas, she did, and this makes the third caliper that's being replaced since I bought her about 3 months ago. Annoyed at myself for not replacing this one when I replaced the second one that locked up on me several weeks ago. Annoyed that I have to pay someone else that's trying to convince me that I need an entire brake job in addition to replacing the caliper. Annoyed that I could have done this for less than $60 and now have to pay $129 and fight off the "upsell" from the tire place that now has my girl up in the air!!! I think my hair just got a little thinner to boot
The moral of this story?........
If you ever find yourself with a caliper locking up, Go ahead and replace the other 3 while your at it. It will cost you just over $200 bucks from your local auto parts store and you won't find yourself stuck in The middle of a 12+ hour drive cussing at yourself in the middle of a town you've never heard of searching for "brakes" on the map app of your iPhone.
The end
Sent from AutoGuide.com App
'06 F250 CC FX4 - 127k miles
Under the hood
EGR Delete, Upgraded oil cooler, upgraded stc fiting /w new HPOP, Blue Spring, 4" Turbo Back, SCT tuner /w Wildman Extreme & Street tune, Sinister Diesel Coolant Filter
studs to come
In the cab
Pillar Glowshift gauge package (EoP/Fuel press/EGT), Dashboss
Alpine touchscreen nav head unit, bluetooth, Phoenix Gold 4-channel amp, JL Audio's 6.5 components up front, 5x7's in rear doors, 10" sub behind seats.
mrc228 is offline
post #2 of 47 Old 06-07-2013, 12:02 PM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
they dont just "go bad" like that, I'd check the boster and for dirty fluid...
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 47 Old 06-07-2013, 12:11 PM Thread Starter
mrc228's Avatar
After the second one I completely flushed the lines. I think that the old fluid plus 126k miles lead to trash in the lines??? (Not a brake guy) I should have gone ahead and replaced the other 2 calipers at that time but I'd hoped that the flush would prevent further issues.
Lol obviously I thought wrong!!
What about the booster could be causing the issue? None of the new calipers have had any issues since I put them on.
Under the hood
studs to come
In the cab
mrc228 is offline
post #4 of 47 Old 06-07-2013, 12:32 PM
ZMANN's Avatar
Quoted: 1781 Post(s)
Well hopefully the flush helped future issues
Brake fluid is Hydroponic and may have attracted water into the system
and caused your caliper issues
also bad rotors can be hard on calipers if they make them pulse rapidly and head up
We Miss you Ronnie
ZMANN is offline
post #5 of 47 Old 06-07-2013, 12:34 PM
I'm on my 3rd set of calipers on all 4 corners. I've replaced every flex line on the truck, flushed the brake fluid, regreased the slides, anti seize on the brake pad tabs/ears. All this and like clockwork every 30,000 miles the crap starts again. It's bad when the pads outlast the calipers.
darenative is offline
post #6 of 47 Old 06-07-2013, 01:02 PM Thread Starter
mrc228's Avatar
I've heard these trucks eat calipers. Wonder if an aftermarket solution is the answer? Hate to go spending $300 on a caliper but since I'm spending that right now cause I'm on the road it may be worth it in the long run.
Zmann, I was really careful not to introduce any water into the system when I did the flush. Made sure to do it on a nice dry day etc. I can't feel any kind of pulsing in the brakes that would indicate a bad rotor. Even the 2 that have been done by the dealer and now this place (still waiting btw) confirmed the rotors are in good shape. Not disputing any of the things you mentioned though. I'll keep it in mind moving forward.
Under the hood
studs to come
In the cab
mrc228 is offline
post #7 of 47 Old 06-07-2013, 01:04 PM
Quoted: 862 Post(s)
Feedback Score: 3 reviews
CHANGE THE MASTER CYLINDER. Its got leak by in the valve body from the back to front chamber and its not letting the pressure completely bleed off. FWIW it will do it intermittently so you that's why it seems like you will have it fixed when you change calipers.
Corey@CNCFAB is offline
post #8 of 47 Old 06-07-2013, 01:09 PM
ZMANN's Avatar
I was saying your old fluid may have been contaminated
not your flushed fluid
if it makes you feel better I am on my stock calipers at 95,000
We Miss you Ronnie
ZMANN is offline
post #9 of 47 Old 06-07-2013, 01:17 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Damn! Sorry to hear about your problem, Glad you got it fixed tho. Atleast for now.
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #10 of 47 Old 06-07-2013, 01:33 PM Thread Starter
mrc228's Avatar
Lol strangely... It does not!!
And it continues here at the tire place.. The got the caliper for the left rear because of the rear mount vs. front mount caliper thing some of these trucks have. Wonder what option puts the calipers on the front side of the axle? This was an issue when I did the other rear cal.
Still another 6 hours on the road to look forward too after I get out of here. Oh joy!
Under the hood
studs to come
In the cab
mrc228 is offline
