FICM removal and bolts question. - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-05-2013, 03:49 PM Thread Starter
Whatsup fellas?
So I got some money together to get Ed at ficm repair to fix my ficm.
I pop the hood, remove the coolant lines from degas bottle, unbolt it and push aside, and what do I find?
My ficm is just sitting there, not a bolt one in the darn thing.
Then, I go to remove the plugs and pull her out,
I get the first one easy, but there others wont budge.
So my two questions are:
1. Any tips or tricks to remove those dadgum things?
2. To replace those bolts could I just run to a hardware store, or is Ford gonna make a pretty penny from me?
Clint.
2005 F250 6.0 CCSB Lariat
SCT w/ tunes from QuickTricks
140 amp motorcraft alt
Isspro Gauges
Zoodad
Blue Spring Mod
High Idle Mod
Rotella T6
SuperLift 4 Inch Lift
20x12 Fuel Hostage w/ 35x12.50 Toyo M/T
Harley Davidson Headlights
HID Head and Foglights
Pioneer Indash
5% Tint
to come:
MBRP
more lift
and who knows..
RidingHigh05 is offline
post #2 of 8 Old 06-05-2013, 04:52 PM
Snake's Avatar
Quoted: 47 Post(s)
Connectors have locks on both sides that must be pushed in to remove them from the FICM. Be gentle.
Best bet for bolts is Ford. They might be be more expensive, but you won't spend days trying to determine and locate the right size.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #3 of 8 Old 06-05-2013, 05:14 PM Thread Starter
I went back out and the other two came off pretty easy. Now to get her shipped off, and get the bolts.
Yeah, I figured ford would probably be. The best bet. I reckon ill reroute the ccv while I'm in there.
Praying Ed does his magic, and makes my truck new again.
Clint.
Isspro Gauges
Zoodad
Blue Spring Mod
High Idle Mod
Rotella T6
Pioneer Indash
5% Tint
to come:
MBRP
more lift
and who knows..
post #4 of 8 Old 06-05-2013, 07:53 PM
406to907's Avatar
Just did this same thing last weekend, my FICM wasn't really attached by bolts, more studs sticking up with a tapered nut/washer type thing which held the FICM into place? not sure the technical term for the type of fastner, went pretty smooth. Getting things plugged back in was a bit more of a chore. Anyways the main reason I'm posting this is because you should have Ed do the ATLAS 40 while he's got your FICM, well worth the extra coin.
06 6.0 CCSB: 4.5" BDS Lift, 18" XD Rims, 35" Trail Grapplers, Custom front bumper, Rigid Flood lights, 5" Diamond Eye Turbo Back Exhaust, Edge CTS Insight, High Idle Mod, FICM Repair.com premium FICM W/Lifetime warranty, ATLAS 40 Tune, Blue Spring Mod, SCT with Custom Tunes, EGR delete, coolant filter kit...
406to907 is offline
post #5 of 8 Old 06-05-2013, 08:33 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
100% agree with the Atlas 40...but if you don't tow at all go with the Atlas 80!!! Big fun!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 8 Old 06-06-2013, 08:43 AM Thread Starter
Well I planned on doing the Atlas 40 at the same time, but money is TIGHT right now.
If I had another vehicle I wouldn't even be getting this done.
I've been out of work for 4 months and as of yesterday the doc says it'll be atleast another 2 months.
Clint.
Isspro Gauges
Zoodad
Blue Spring Mod
High Idle Mod
Rotella T6
Pioneer Indash
5% Tint
to come:
MBRP
more lift
and who knows..
post #7 of 8 Old 06-16-2013, 11:10 AM Thread Starter
Well I got her back together. As everyone knows, ed is awesome, highly recomend him.
Did the ccv mod while I was at it.
Clint.
Isspro Gauges
Zoodad
Blue Spring Mod
High Idle Mod
Rotella T6
Pioneer Indash
5% Tint
to come:
MBRP
more lift
and who knows..
post #8 of 8 Old 06-16-2013, 11:58 AM
You got studs? Didn't think it was recommend to run the atlas 80 without being studded.
Sent from AutoGuide.com App
Alpha Male is offline
