No start issue.. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-05-2013, 09:42 AM Thread Starter
jjvizinat's Avatar
No start issue..
Ive had my 6.0 for a couple weeks now, no issues when I first got it. Gradually took longer an longer to start (2-5 sec) (cold start). Now it never starts at first crank when its cold. After I drive a bit its fine an will start right up.
Glow plugs light goes off so I would think there warm? Just had my oil changed by Ford an they said batteries are good. Not having any coolant issues. I have no idea how to check FICM so kinda lost on this. Any help is appreciated.
EGR delete, 4" turbo back exhaust, still not studded, 62k miles
jjvizinat is offline
post #2 of 4 Old 06-07-2013, 09:04 PM
Theres a video on youtube and on the threads. Just search around it will say circuitboardmedics.com or something like that as a watermark. Thats what I used. Also bad glowplug wont actually turn CEL on, its a hidden code. I would start with the ficm and look around for an autozone or something, sometimes they have decent scanners that will pick up the glow plugs
ajfrac is offline
post #3 of 4 Old 06-08-2013, 02:09 AM
john galt's Avatar
Quoted: 1226 Post(s)
my early 04 did the same thing with a bad hpop. not ure if that means anything but trying to help.
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #4 of 4 Old 06-08-2013, 04:24 AM
I just had same issue...
Except I fixed it as soon as I noticed the longer crank.
For me it was the passenger side dummy plug o-ring became damaged and was allowing the passenger side oil rail to leak down. The HPOP then had to fill the rail before it could start and it took a longer crank.
Replaced my Stand pipes and Dummy plugs with the updated units with Teflon backer rings and all is fine again. Hope this helps you as well.
Starr_302 is offline
