vac pump wont shut off, ac only on defrost - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-04-2013, 07:25 AM Thread Starter
This last week I was on vacation and my AC stopped working right. The air will only go to defrost. I read around a bit and know I have a vacuum problem. I checked the few things that people specifically said in other posts like the gray tube that often un plugs and it looked good. It also seems like all of the other tubes and hoses are connected where they ought to be.
Last night while going over things again I did key on engine off and the vac pump turned on but didn't turn off. When I pulled a line and stuck my finger on it there was suction so I think the pump is good. People have said that they test for leaks at the hubs and whatnot but I'm a total noob and don't know how to do that. Can someone help me out and describe the process and maybe suggestions on what lines and where they are to check.
Thanks. I was in Moab doing a little bit of off roading in the beast so I wouldn't be surprised if I popped something loose. I just don't know how to test for leaks. And by the way my beast did fantastic.
2007 F350 6.0L FX4 Lariat CCLB
MBRP 4" w/ 5" Tip turbo back, no cat
Toyo MT's 315/60/R20
Edge Insight CS w/EGT probe
SnugTop Super Sport
sanctified is offline
post #2 of 7 Old 06-04-2013, 07:31 AM
Colin7.3's Avatar
The lines are on your hubs. Rubber lines that push over a nipple. Mine leaks so I plugged them and now my air works perfect
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #3 of 7 Old 06-04-2013, 07:34 AM Thread Starter
So you just manually lock in when you need 4x4? That is what I ended up hafting to do all weekend. I would like everything to just work though.
SnugTop Super Sport
post #4 of 7 Old 06-04-2013, 07:52 AM
Colin7.3's Avatar
Exactly what. I do. I'm switching to full manuals soon anyway.
Start at the wheel side hoses and just follow up to the solenoid and pump. Look for cracks, cuts or just pulled apart lines
Colin7.3 is offline
post #5 of 7 Old 07-23-2013, 04:07 PM
justinlogue5_0's Avatar
Where do I lug these lines off at? Got a pic? I thought I plugged it off where lines come from hubs still does it. Do I cap the pump itself or???? Thanks.
It gets me there, What more could I ask for?
justinlogue5_0 is offline
post #6 of 7 Old 07-24-2013, 02:26 AM
If you plugged the ends and it still runs you have nuther leak in the hose/hoses further up the line or a bad vac solenoid valve or hole in resivoir.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #7 of 7 Old 07-24-2013, 05:38 AM
Any more detail on how the pump or solenoid works? I can vacume check resevoir and lines but not sure how to check the rest? Thanks!
